Home » Eclipse Projects » GEF » How to mix GEF's selection display into the PropertySheet with other selections from different Views
How to mix GEF's selection display into the PropertySheet with other selections from different Views [message #142464] Mon, 12 July 2004 13:26 Go to next message
Originally posted by: ra.classys.net
Hello everyone,
After I read again my previous question i realized my chances of getting=
an answer were quite low.
I have the following problem.
In a MultiPageEditor i have a few pages each of them containing an edito=
r. =
One of them is GEF other is a handcrafted JFace (with a ListView and som=
e =
buttons) called ModesetInterface.
When a click happens on an item of this ListView the PropertySheet is =
synchronized with it because the ModesetInterface registers itself to th=
e =
site as the SelectionProvider (this i learned from the article "Take =
control of your properties).
When i switch to the GEF editor, it no longer has the ability to sync th=
e =
selected node with the property sheet. (this part works neatly if I cut =
of =
the other's editor registration as the SelectionProvider).
How can i solve this?
Ra
Re: How to mix GEF's selection display into the PropertySheet with other selections from different V [message #142475 is a reply to message #142464] Mon, 12 July 2004 14:01 Go to previous messageGo to next message
change the selection provider every time the page changes.
"Rares Pop" <ra@classys.net> wrote in message
news:opsa1b1r046mykrh@morpheus.classys.net...
Hello everyone,
In a MultiPageEditor i have a few pages each of them containing an editor.
One of them is GEF other is a handcrafted JFace (with a ListView and some
synchronized with it because the ModesetInterface registers itself to the
When i switch to the GEF editor, it no longer has the ability to sync the
selected node with the property sheet. (this part works neatly if I cut of
Ra
Re: How to mix GEF's selection display into the PropertySheet with other selections from different V [message #142541 is a reply to message #142475] Tue, 13 July 2004 04:04 Go to previous messageGo to next message
thanks you for answering.
how do i do that?
is GraphicalEditorWithPallete or one of its members implementing =
ISelectionProvider? who?
or do i need to make an implementation myself...
On Mon, 12 Jul 2004 14:01:33 -0400, Randy Hudson <none@us.ibm.com> wrote=
> Hello everyone,
> After I read again my previous question i realized my chances of getti=
ng
> In a MultiPageEditor i have a few pages each of them containing an =
> editor.
> One of them is GEF other is a handcrafted JFace (with a ListView and s=
ome
> synchronized with it because the ModesetInterface registers itself to =
the
> When i switch to the GEF editor, it no longer has the ability to sync =
the
> selected node with the property sheet. (this part works neatly if I cu=
t =
> of
> Regards,
> Ra
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: How to mix GEF's selection display into the PropertySheet with other selections from different V [message #142557 is a reply to message #142541] Tue, 13 July 2004 05:16 Go to previous messageGo to next message
Still problems....
I have found out that the SelectionProvider implementor for a GEF editor=
is by default
the editor.getGraphicalEditor();
the problem remains though:
when I change the page in the MPE (MultiPageEditor) i also change the =
SelectionProvider accordingly. yet it doesn't work. whoever claims to be=
the SelectionProvider first remains regardless of setSelectionProvider()=
calls that happens after that.
BUG?
> how do i do that?
> On Mon, 12 Jul 2004 14:01:33 -0400, Randy Hudson <none@us.ibm.com> wro=
te:
>> Hello everyone,
>> After I read again my previous question i realized my chances of gett=
ing
>> editor.
>> One of them is GEF other is a handcrafted JFace (with a ListView and =
>> some
>> When a click happens on an item of this ListView the PropertySheet is=
>> synchronized with it because the ModesetInterface registers itself to=
>> the
>> When i switch to the GEF editor, it no longer has the ability to sync=
>> the
>> selected node with the property sheet. (this part works neatly if I c=
ut =
>> of
>> Regards,
>> Ra
Re: How to mix GEF's selection display into the PropertySheet with other selections from different V [message #142575 is a reply to message #142557] Tue, 13 July 2004 06:52 Go to previous messageGo to next message
Just wanted to finish this monolog here with the solution to this proble=
m.
MultiPageEditor has its own SelectionProvider that handles the =
distribution/synchronization of selections throughout the member pages. =
Therefore there was no need to make a paralel system for claming the =
SelectionProvider role for all my pages.
The only thing required is that all the pages added should contain =
IEditorPart implementors and they should be added
with the method addPage(IEditorPart , IEditorInput) and certainly NOT th=
e =
simple addPage(Control)
On Tue, 13 Jul 2004 12:16:36 +0300, Rares Pop <ra@classys.net> wrote:
> Still problems....
> I have found out that the SelectionProvider implementor for a GEF edit=
or =
> is by default
> SelectionProvider accordingly. yet it doesn't work. whoever claims to =
be =
> the SelectionProvider first remains regardless of setSelectionProvider=
> BUG?
>> how do i do that?
>> On Mon, 12 Jul 2004 14:01:33 -0400, Randy Hudson <none@us.ibm.com> =
>>> Hello everyone,
>>> After I read again my previous question i realized my chances of =
>>> getting
>>> editor.
>>> One of them is GEF other is a handcrafted JFace (with a ListView and=
>>> some
>>> When a click happens on an item of this ListView the PropertySheet i=
s
>>> synchronized with it because the ModesetInterface registers itself t=
o =
>>> the
>>> site as the SelectionProvider (this i learned from the article "Take=
>>> When i switch to the GEF editor, it no longer has the ability to syn=
c =
>>> the
>>> selected node with the property sheet. (this part works neatly if I =
>>> cut of
>>> Regards,
>>> Ra
Re: How to mix GEF's selection display into the PropertySheet with other selections from different V [message #142613 is a reply to message #142575] Tue, 13 July 2004 14:37 Go to previous message
MultiPageEditor is a hack, and you cannot take editors designed to work by
themselves and place them inside a multipage editor. See selectionChanged
in GraphicalEditor for one reason why this approach doesn't work.
news:opsa2ohtcr6mykrh@morpheus.classys.net...
Just wanted to finish this monolog here with the solution to this problem.
with the method addPage(IEditorPart , IEditorInput) and certainly NOT the
> Still problems....
> is by default
> BUG?
>> how do i do that?
>>> Hello everyone,
>>> getting
>>> editor.
>>> some
>>> the
>>> the
>>> cut of
>>> Regards,
>>> Ra
Previous Topic:How to change the label displayed for ZoomIn action
Next Topic:GEF on ViewPart
Current Time: Sat Jul 19 15:33:45 EDT 2025
Powered by FUDForum. Page generated in 0.26401 seconds
