Viewing custom components? [message #1425008] |
Tue, 16 September 2014 14:48  |
Hello Everyone,
I am using WindowsBuilder and ApplicationWindows for each of my forms.
I have to write an application that draws a preview of what will be printed.
I have a custom JPanel I use to draw on and it does not show up in Design view.
Is there a way to change that?
Thank you,
Antoine
ps: The code below shows the proof of concept (yes, drawing is possible in Java) and works in Eclipse/JavaEE
package views;
import java.awt.event.ActionListener;
import java.awt.event.ActionEvent;
import java.awt.Color;
import java.awt.Dimension;
import java.awt.EventQueue;
import java.awt.Graphics;
import java.awt.Rectangle;
import java.util.ArrayList;
import java.util.Iterator;
import javax.swing.*;
import java.awt.Toolkit;
import com.jgoodies.forms.factories.DefaultComponentFactory;
import java.awt.BorderLayout;
public class appMainWindow
class PdfLocation
public double xPos;
public double yPos;
class DrawCanvas extends JPanel
public void paintComponent(Graphics g)
super.paintComponent(g);
for (PdfLocation p : PdfLocations)
g.drawRect((int)p.xPos, (int)p.yPos, 35, 20);
repaint();
public void AddRectangle()
PdfImagesCount++;
lblPdfCount.setText(Integer.toString(PdfImagesCount));
PdfLocation rect = new PdfLocation();
if (PdfLocations.isEmpty() == false)
PdfLocation spot = PdfLocations.get(PdfLocations.size() - 1);
rect.xPos = spot.xPos + 45;
rect.yPos = 10;
else
rect.xPos = 10;
rect.yPos = 10;
PdfLocations.add(rect);
private JFrame frame;
public ArrayList<PdfLocation> PdfLocations = new ArrayList<PdfLocation>();
public int PdfImagesCount = 0;
public static final int CANVAS_HEIGHT = 700;
public static final int CANVAS_WIDTH = 1000;
private DrawCanvas canvas;
private JLabel lblPdfCount;
private JButton btnOk;
public static void main(String[] args) { EventQueue.invokeLater(new Runnable() { public void run() { try { appMainWindow window = new appMainWindow(); window.frame.setVisible(true); } catch (Exception e) { e.printStackTrace(); } } }); }
public appMainWindow()
// Set up a custom drawing JPanel
canvas = new DrawCanvas();
canvas.setBackground(Color.WHITE);
canvas.setBounds(150, 25, CANVAS_WIDTH, CANVAS_HEIGHT);
initialize();
private void initialize()
frame = new JFrame();
frame.setIconImage(Toolkit.getDefaultToolkit().getImage(appMainWindow.class.getResource("/icons/appIcon2.png")));
frame.setBounds(100, 100, 1200, 728);
frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
frame.setResizable(true);
frame.setTitle("Shaareable Apps Presents ~ Pdf Imposition Monster");
JMenuBar menuBar = new JMenuBar();
frame.setJMenuBar(menuBar);
JMenu mnMenu = new JMenu("Menu");
menuBar.add(mnMenu);
JMenuItem mntmTest = new JMenuItem("test");
mntmTest.setIcon(new ImageIcon(appMainWindow.class.getResource("/icons/Blue-Monster-icon.png")));
mnMenu.add(mntmTest);
frame.getContentPane().setLayout(null);
lblPdfCount = new JLabel("");
lblPdfCount.setBounds(92, 325, 61, 16);
frame.getContentPane().add(lblPdfCount);
btnOk = new JButton("ok");
btnOk.addActionListener(new ActionListener() {
public void actionPerformed(ActionEvent arg0)
AddRectangle();
frame.repaint();
btnOk.setBounds(22, 172, 75, 29);
frame.getContentPane().add(btnOk);
frame.getContentPane().add(canvas);
FUDForum. Page generated in 0.11209 seconds
