Home » Modeling » TMF (Xtext) » [xtext] problem saving a model to dsl file
icon9.gif  [xtext] problem saving a model to dsl file [message #1424204] Mon, 15 September 2014 12:35 Go to next message
Dear all,
I have defined a DSL (gorgiasdsl) and generated the xtext artifacts. I can load a model and manipulate it using EMF. However, when it comes to saving the model I get a "ValueConverterWithValueException: String literal is not properly closed" error.
What can be the problem?
I attach my code and the StackTrace:
//load model fro dsl
Injector injector = new GorgiasDslStandaloneSetup().createInjectorAndDoEMFRegistration();
XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
Resource resource = resourceSet.getResource(URI.createURI("file:///C:\\kb.gorgiasdsl"), true);
GorgiasProgram model = (GorgiasProgram) resource.getContents().get(0);
//model is correct
//save model
try {
 HashMap saveOptions = new HashMap();
 saveOptions.put(XtextResource.OPTION_ENCODING, "UTF8");
 resource.save(new FileOutputStream("myapplication.gorgiasdsl"), saveOptions);		} catch (IOException e) {
 e.printStackTrace();
Exception in thread "main" org.eclipse.xtext.conversion.ValueConverterWithValueException: String literal is not properly closed
	at org.eclipse.xtext.conversion.impl.STRINGValueConverter.convertFromString(STRINGValueConverter.java:184)
	at org.eclipse.xtext.conversion.impl.STRINGValueConverter.toValue(STRINGValueConverter.java:32)
	at org.eclipse.xtext.conversion.impl.STRINGValueConverter.toValue(STRINGValueConverter.java:1)
	at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.toValue(AbstractDeclarativeValueConverterService.java:72)
	at org.eclipse.xtext.serializer.tokens.ValueSerializer.serializeAssignedValue(ValueSerializer.java:52)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.getToken(SequenceFeeder.java:462)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:220)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:407)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:449)
	at gr.tuc.amcl.xtext.gorgiasdsl.serializer.GorgiasDslSemanticSequencer.sequence_Term(GorgiasDslSemanticSequencer.java:349)
	at gr.tuc.amcl.xtext.gorgiasdsl.serializer.GorgiasDslSemanticSequencer.createSequence(GorgiasDslSemanticSequencer.java:143)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptEObjectRuleCall(SequenceFeeder.java:299)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptRuleCall(SequenceFeeder.java:325)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:239)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:400)
	at gr.tuc.amcl.xtext.gorgiasdsl.serializer.GorgiasDslSemanticSequencer.sequence_TermList(GorgiasDslSemanticSequencer.java:340)
	at gr.tuc.amcl.xtext.gorgiasdsl.serializer.GorgiasDslSemanticSequencer.createSequence(GorgiasDslSemanticSequencer.java:149)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:222)
	at gr.tuc.amcl.xtext.gorgiasdsl.serializer.GorgiasDslSemanticSequencer.sequence_Predicate(GorgiasDslSemanticSequencer.java:288)
	at gr.tuc.amcl.xtext.gorgiasdsl.serializer.GorgiasDslSemanticSequencer.createSequence(GorgiasDslSemanticSequencer.java:101)
	at gr.tuc.amcl.xtext.gorgiasdsl.serializer.GorgiasDslSemanticSequencer.sequence_Clause(GorgiasDslSemanticSequencer.java:178)
	at gr.tuc.amcl.xtext.gorgiasdsl.serializer.GorgiasDslSemanticSequencer.createSequence(GorgiasDslSemanticSequencer.java:53)
	at gr.tuc.amcl.xtext.gorgiasdsl.serializer.GorgiasDslSemanticSequencer.sequence_GorgiasProgram(GorgiasDslSemanticSequencer.java:236)
	at gr.tuc.amcl.xtext.gorgiasdsl.serializer.GorgiasDslSemanticSequencer.createSequence(GorgiasDslSemanticSequencer.java:83)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:85)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:108)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:130)
	at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:336)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1430)
	at Test.main(Test.java:65)
[Updated on: Mon, 15 September 2014 12:36] by Moderator
Re: "ValueConverterWithValueException: String literal is not properly closed" when [message #1424208 is a reply to message #1424204] Mon, 15 September 2014 12:42 Go to previous message
please set a breakpoint in
ValueSerializer.serializeAssignedValue(EObject, RuleCall, Object, INode,
Acceptor) and try to figure out what's wrong with the node.
Except from that, I think there is a missing try-catch in the framework
code. Could you please file a ticket?
To workaround that one, you may want to specialize the ValueSerializer
and override the questionable method.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 15.09.14 18:35, schrieb Nikos Mising name:
> Dear all,
> Resource resource =
> //model is correct
> //save model
> try {
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:[shameless plug] MDD-related conference in .nl
Next Topic:Xtext example how to configure validation via preferences
Current Time: Sat Jul 19 16:36:37 EDT 2025
Powered by FUDForum. Page generated in 0.03633 seconds
