A diagram of XMI [message #1424044] |
Mon, 15 September 2014 07:24  |
Hello.
I have a XMI and I wish to see it graphically, ie, seeing it as a diagram, similar to a UML diagram, I can do so automatic in eclipse?
Jose
Re: A diagram of XMI [message #1424550 is a reply to message #1424044] |
Tue, 16 September 2014 01:23  |
Jose,
This question is not related to the XML Schema API provided by the XSD
project. Perhaps you meant to post this on eclipse.tools.emf. In any
case, there isn't a generic visualization of arbitrary models although
that would be kind of cool. You could either build one for a specific
model using GMF or Graphiti, or you could transform/map you instance to
UML or to Ecore and use UML's or Ecore's graphical editor to visualize
that. For example, *.xsd instances can be transformed to *.ecore
instances, and using the Ecore Tools graphical editor, you can visualize
the *.ecore instances.
On 15/09/2014 1:24 PM, Jose Texier wrote:
> Hello.
> Jose
FUDForum. Page generated in 0.04109 seconds
