Home » Archived » EMF-IncQuery » call queries IncQuery API
call queries IncQuery API [message #1422048] Fri, 12 September 2014 04:41 Go to next message
I have the School and School Incquery examples from your site. I'm trying to call queries by code (not running another eclipse runtime application and press the button to apply the queries. ).
I came to this:
hl.executeDemo_GenericAPI_LoadFromEIQ(schoolEcore, schoolQueries "Schhool.incquery.schoolsNames"));
I run this as a java application . I have this error:
Cannot load erroneous query specification Schhool.incquery.schoolsNames
I do not understand why . Also , I can not find where I load the emf resource . How I pass the xml resource to know what to query ?
Thank you !
Re: call queries IncQuery API [message #1422218 is a reply to message #1422048] Fri, 12 September 2014 10:01 Go to previous messageGo to next message
Is "Schhool" misspelled, or did you really rename the package that way?
In the latter case, are you sure the pattern is free of errors when you edit it in the IDE?
If this question is identical to the other thread, we should continue there.
Gábor
Re: call queries IncQuery API [message #1422222 is a reply to message #1422048] Fri, 12 September 2014 10:07 Go to previous message
Hi Made Leine,
The LoadFromEIQ method looks for a query specification in the package Schhool.incquery.schoolsNames. I guess, the 'Schhool' is misspelled, and it should be correctly 'school' (with lowercase and a single 'h').
The fully qualified name of a pattern is determined similarly to Java classes: the container package followed by the name of the pattern.
Zoltán
Previous Topic:IncQuery Explorer and Xtext resources
Next Topic:how load xml emf resource using api
Current Time: Sat Jul 19 09:04:21 EDT 2025
Powered by FUDForum. Page generated in 0.03108 seconds
