Home » Eclipse Projects » e(fx)clipse » e4 fx application simply does not start anymore
e4 fx application simply does not start anymore [message #1417447] Fri, 05 September 2014 09:04 Go to next message
I have Luna with e(fx)clipse 1.0 and create and e4 javafx application. I don't know what I did, but now my app simply does not start anymore. I deleted the workspace, the runtime anything, re-created launch configuration from the product, and yet the only thing shown in console is nothing.
That is, something seems to get launched
marco            1780   3,4  0,8  8368640 139940   ??  S     3:03pm   0:02.36 /Library/Java/JavaVirtualMachines/jdk1.8.0_20.jdk/Contents/Home/bin/java -XstartOnFirstThread -Dosgi.framework.extensions=org.eclipse.fx.osgi -Dfile.encoding=UTF-8 -classpath /Users/marco/Development/workspaces/redsalt/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar org.eclipse.equinox.launcher.Main -launcher /Users/marco/Development/workspaces/redsalt/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/Eclipse.app/Contents/MacOS/eclipse -name Eclipse -showsplash 600 -product org.redsalt.e4fx.app.product -data /Users/marco/Development/workspaces/redsalt/../runtime-org.redsalt.e4fx.app.product.product -configuration file:/Users/marco/Development/workspaces/redsalt/.metadata/.plugins/org.eclipse.pde.core/org.redsalt.e4fx.app.product.product/ -dev file:/Users/marco/Development/workspaces/redsalt/.metadata/.plugins/org.eclipse.pde.core/org.redsalt.e4fx.app.product.product/dev.properties -os macosx -ws cocoa -arch x86_64 -nl de_DE -consoleLog
but thats about it, nothing happens until i press Terminate in the console view.
Any hints?! I even set up a clean new Eclipse installation ... did not work!
Re: e4 fx application simply does not start anymore [message #1417629 is a reply to message #1417447] Fri, 05 September 2014 16:25 Go to previous messageGo to next message
Well, fyi : I could only fix it by creating a new sample application, taking the resp. launch configuration and adapt it to the currently not running app. It seems like the fx app is only runnable when there exists the pre-configured launch configuration.
Re: e4 fx application simply does not start anymore [message #1417752 is a reply to message #1417629] Fri, 05 September 2014 20:37 Go to previous messageGo to next message
Yes never regenerate the config - it will block because dumb Eclipse is
loading SWT-Libs if you pass e.g. cocoa as ws.
Tom
Re: e4 fx application simply does not start anymore [message #1420052 is a reply to message #1417752] Tue, 09 September 2014 08:47 Go to previous message
Hey Tom,
thanks a lot ... just run into it again, and hoped that I got some answer on it! Removing the parameter worked out, and I also clear the config now!
thanks
Previous Topic:+1 for "Eclipse DI Feature" in "OSGi Application Projekt"
Next Topic:e(fx)clipse 1.0 failed to start fxgraph editor on Luna 4.4
Current Time: Sat Jul 19 22:25:23 EDT 2025
Powered by FUDForum. Page generated in 0.03397 seconds
