External Lib : Lua LOOP not running [message #1416750] |
Mon, 03 December 2012 15:04  |
I am new to LDT ( using version 0.9) under Debian Linux and I like it so far.
I can run Lua files within the LDT and it shows the output in the console.
However, if I use external libraries, errors will appear when trying to run them.
For example I tried to use the http://loop.luaforge.net/index.html :
local oo = require "loop.base"
I installed LOOP via LuaRocks and I can run classes based on LOOP without any problems on the Linux Shell.
However, running it in Linux will cause the following error message :
> Exception in thread "main" com.naef.jnlua.LuaRuntimeException: /home/dev/lua/src/main.lua:1: module 'loop.base' not found:
> no field package.preload['loop.base']
> no file '/home/dev/lua/src/loop/base.lua'
> no file '/home/dev/lua/src/loop/base/init.lua'
> no file '/home/dev/lua/src/loop/base.luac'
> no file '/home/dev/lua/src/loop/base/init.luac'
> no file './loop/base.so'
> no file '/usr/local/lib/lua/5.1/loop/base.so'
> no file '/usr/lib/lua/5.1/loop/base.so'
> no file '/usr/local/lib/lua/5.1/loadall.so'
> no file './loop.so'
> no file '/usr/local/lib/lua/5.1/loop.so'
> no file '/usr/lib/lua/5.1/loop.so'
> at com.naef.jnlua.LuaState.lua_pcall(Native Method)
> at com.naef.jnlua.LuaState.call(LuaState.java:555)
> at org.eclipse.koneki.ldt.support.lua51.internal.interpreter.JNLuaLauncher.run(JNLuaLauncher.java:122)
> at org.eclipse.koneki.ldt.support.lua51.internal.interpreter.JNLuaLauncher.main(JNLuaLauncher.java:137)
How can I fix it so that I can use LDT for LOOP-based lua files, too.
FUDForum. Page generated in 0.03329 seconds
