Home » Modeling » TMF (Xtext) » Unit Test for DSL with dependent DSL(Unit Test for DSL with dependent DSL)
Unit Test for DSL with dependent DSL [message #1244284] Wed, 12 February 2014 00:45 Go to next message
I am also trying to write unit tests including a dependent DSL. The grammar looks like this.
grammar abc.Dsl with org.eclipse.xtext.common.Terminals
generate dsl "http://abc/MainDsl"
import "http://abc/SubDsl" as subdsl
In the Unit test you inject the Model (in this case the MainDsl-Model) with:
@InjectWith(typeof(MainDslInjectorProvider))
@RunWith(typeof(XtextRunner))
class AssertFieldParserTest {
  @Inject extension ParseHelper<MainDslModel>
The problem is that this only allows me to parse the MainDsl, but not the SubDsl. How can this be achieved? I found a hint in a blog http://christiandietrich.wordpress.com/2012/05/08/unittesting-xtend-generators but the modified ParseHelper does not work for me; it still only parses one model, and not both. And I cannot inject a second ParseHelper. Does anyone have a solution to this? Eventually I need to verify my code generation and that I can only achieve having access to both models.
Sebastian
Re: Unit Test for DSL with dependent DSL [message #1244331 is a reply to message #1244284] Wed, 12 February 2014 02:11 Go to previous messageGo to next message
Can please someone share code I can use and fix. It takes to much
time to do everything myself to reproduce the problem
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Unit Test for DSL with dependent DSL [message #1245003 is a reply to message #1244331] Thu, 13 February 2014 01:36 Go to previous messageGo to next message
Hi Christian,
I quickly set up the two DSLs. The MainDsl imports the SubDSL. For the ease of use both just define one element. I also added a test module using the DSLs.
Eventually the sub files will look like this:
Sub - hyperlink newPage {"//*abc" : XPATH}
Main - click newPage (where newPage is the element defined in the sub)
Now I want to write a unit test where I parse both language models, and when I assert the 'click' element, I want to have access to the hyperlink associated via the 'newPage" reference.
I hope that illustrates my problem. Pls let me know if you need further information; I appreciate your support!
Sebastian
[Updated on: Thu, 13 February 2014 01:37] by Moderator
Re: Unit Test for DSL with dependent DSL [message #1245017 is a reply to message #1245003] Thu, 13 February 2014 02:03 Go to previous messageGo to next message
Hmm this works strainght forward...
@InjectWith(typeof(ExtMainDslInjectorProvider))
class ClickHyperlinkTest {
	@Inject extension ExtendedParseHelper<Model>
	@Inject Provider <ResourceSet> rsp
	 * Have to hack the test a bit in order to have access to both DSL (.define and .test)
	@Test
	def void parseForms() {
		val rs = rsp.get
		'''.parse(URI.createURI("test.sub"), rs)
		val domainModel = '''
			click newPage
		'''.parse(rs)
		assertEquals(ElementType.XPATH, domainModel.fields.get(0).link.findBy.type)
Re: Unit Test for DSL with dependent DSL [message #1245075 is a reply to message #1245017] Thu, 13 February 2014 04:03 Go to previous messageGo to next message
Thanks, that works like a charme. I see now how you use the Provider and the Resource, and pass it to the ParseHelper. That makes sense!
Sebastian
[Updated on: Thu, 13 February 2014 04:22] by Moderator
Re: Unit Test for DSL with dependent DSL [message #1405461 is a reply to message #1245075] Thu, 07 August 2014 08:09 Go to previous messageGo to next message
Is there any way to read this content from file instead of hardcoding in code :
This content should be read from file so that we can pass contents to parse() method.
I tried using parse(InputStream in, URI uriToUse, Map options,ResourceSet resourceSet) but not sure what to pass as options.
Please suggest.
Cheers
Kunal
Re: Unit Test for DSL with dependent DSL [message #1405503 is a reply to message #1405461] Thu, 07 August 2014 09:55 Go to previous messageGo to next message
depends on what you actually want to do.
- create a resource set
- load a bunch of resources
- work with them.
this should be streight forward (of course then you cannot use parsehelper)
Re: Unit Test for DSL with dependent DSL [message #1416000 is a reply to message #1405503] Thu, 04 September 2014 02:02 Go to previous messageGo to next message
For the above case of Running Junit for Dependent DSL's, If I try to run the Junit Test Case from command Line , I am getting below exception:
Guice configuration errors:
1) No implementation for javax.inject.Provider<org.eclipse.emf.ecore.resource.ResourceSet> was bound.
     [java]   while locating javax.inject.Provider<org.eclipse.emf.ecore.resource.ResourceSet>
     [java]     for field at com.mydsl.TestMyDsl.resourceSet(TestMyDsl.java:48)
     [java]   while locating com.mydsl.TestMyDsl
Any Clue, what would be the reason why Guice is not able to locate dependent dsl.
Cheers
Kunal
Re: Unit Test for DSL with dependent DSL [message #1416019 is a reply to message #1416000] Thu, 04 September 2014 02:55 Go to previous messageGo to next message
have no idea on that sry. use e.g. maven tycho works fine for me.
Re: Unit Test for DSL with dependent DSL [message #1416095 is a reply to message #1416019] Thu, 04 September 2014 05:59 Go to previous messageGo to next message
Hi Christian,
I have used ant build script and inside that I am using Junit target to run xtext junit test cases.
Cheers
Kunal
Re: Unit Test for DSL with dependent DSL [message #1416143 is a reply to message #1416095] Thu, 04 September 2014 08:29 Go to previous messageGo to next message
maybe it has something todo with how you run the tests, maybe the injector provider is not working correct then or some caches are not cleaned up.
do you have only one test or multiple?
Re: Unit Test for DSL with dependent DSL [message #1419091 is a reply to message #1416143] Mon, 08 September 2014 00:50 Go to previous messageGo to next message
Hi Christian,
I run multiple test.
Cheers
Kunal
Re: Unit Test for DSL with dependent DSL [message #1419126 is a reply to message #1419091] Mon, 08 September 2014 02:08 Go to previous messageGo to next message
Can you share an example that i can simply take and run/debug
Re: Unit Test for DSL with dependent DSL [message #1419272 is a reply to message #1419126] Mon, 08 September 2014 07:02 Go to previous message
Hi Christian,
Thanks for the reply, I figured out the issue in my code it was all due to below line :
@Inject
private Provider<ResourceSet> resourceSet;
It was unable to find the implementation class to inject the Provider class.
I modified the above declaration and used below code
try {
    	resourceSet = new Provider<ResourceSet>() {
			public ResourceSet get() {
				ResourceSet resourceSet = new ResourceSetImpl();
				return resourceSet;
Thanks a lot for Reply.
Cheers
Kunal
Previous Topic:My DSL plugin install fails
Next Topic:New Xcore build available?
Current Time: Sun Jul 20 09:46:56 EDT 2025
Powered by FUDForum. Page generated in 0.04509 seconds
