Home » Archived » BIRT » Export report to CSV format(Export report to CSV format column names are not proper)
Export report to CSV format [message #1415566] Wed, 03 September 2014 00:34 Go to next message
Hi All Guru's,
I have created a birt report and generating it using birt viewer.It works fine when i eport the report to any format(html,docx,excel, etc..) .
But when i try to export data for the report in CSV format the column names in CSV file are reflecting as column names in DB table column names and not what i specified in rptdesign.
Please help me.
Re: Export report to CSV format [message #1415844 is a reply to message #1415566] Wed, 03 September 2014 16:08 Go to previous messageGo to next message
When exporting the data, it's exporting the bindings, not the report design. This would be why you're getting what you're getting. You could create a csv emitter or use this one from an old contest that was done on the BIRT Developer Center:
http://developer.actuate.com/community/forum/index.php?/files/file/801-csv-emitter-plugin-for-birt/
Re: Export report to CSV format [message #1415877 is a reply to message #1415844] Wed, 03 September 2014 18:08 Go to previous messageGo to next message
Thanks MW for the link. I'm really looking for this one.
Re: Export report to CSV format [message #1435881 is a reply to message #1415566] Thu, 02 October 2014 00:50 Go to previous messageGo to next message
Hello, I just copy "org.eclipse.birt.report.engine.emitter.csv_1.0.0.201110121016.jar"
to eclipse plugin folder, and I try to export file in rptdesign, but I can't see csv format.
can you help me,how to add format csv folder in list export format.
thanks
  • Attachment: exportcsv.PNG
    (Size: 14.07KB, Downloaded 845 times)
Re: Export report to CSV format [message #1441342 is a reply to message #1435881] Thu, 09 October 2014 11:49 Go to previous messageGo to next message
What's your BIRT version?
Re: Export report to CSV format [message #1530254 is a reply to message #1441342] Fri, 26 December 2014 15:05 Go to previous message
hi Michael, when i use this CSV export with BIRT version 4.3.1 the header is coming fine as per the display name, but when i use the same jar in Actuate 11SP4 Fix 3 version, i get the binding column names. Do you have any idea on this?
Previous Topic:Maximo 7.5 BIRT Report
Next Topic:Display labels side by side in cell with left - right alignment
Current Time: Sun Jul 20 18:44:37 EDT 2025
Powered by FUDForum. Page generated in 0.26045 seconds
