Home » Eclipse Projects » Eclipse 4 » Logging on Mac OS(unable to find .log file when product exporting for mac os)
Logging on Mac OS [message #1415399] Tue, 02 September 2014 13:44 Go to next message
Hi all,
I created a small application based on Eclipse 4 platform. I also added some logging via logging service and after exporting the application for windows, everything works fine and I can find a .log file on the following location:
{application root}/workspace/.metadata/.log (folder structure is created when the application is started up first time)
But when I export the application for Mac OS, there is no such folder structure created and I'm not able to find the .log file neither.
I'm not working on Mac at all, so does anyone have a similar experience or could anyone who uses Mac OS help me with this problem.
[Updated on: Tue, 02 September 2014 13:45] by Moderator
Re: Logging on Mac OS [message #1415413 is a reply to message #1415399] Tue, 02 September 2014 14:21 Go to previous message
Have you configured a workspace? E.g., via a command-line argument (-data) or as a system property (osgi.instance.area)? If not, then I believe the app will first try to find/create a workspace alongside the executable (e.g., in the XXXX.app/Contents/MacOS/ directory) if it's writable. Otherwise it uses the default location which is in ~/Documents/workspace.
Brian.
Previous Topic:How to correctly toggle visibility of a Placeholder?
Next Topic:E4 Compatibility Layer Menu Ordering Issues.
Current Time: Sat Jul 19 20:07:37 EDT 2025
Powered by FUDForum. Page generated in 0.02788 seconds
