Command Prompt Issues with Eclipse [message #1415338] |
Tue, 02 September 2014 10:57  |
I have downloaded the eclipse software along with a MinGW GCC Compiler to use for a C programming course, but my problem is that I run my code (it tells me on the console tab at the bottom that the program is running), the command prompt does not come up, prompting me with my program. I can even go into the command prompt window manually and find the .exe file and run the code (which runs properly). I have also editied my PATH in my environment variable settings. I am not sure though what could be causing this command prompt to function improperly, though. Whether it be a simple setting that needs to be changed, or whether my avast anti-virus or some other security type program could be the culprit. I would appreciate any advice or suggestions, and would be happy to provide any additional information.
Thanks in advance.
-Jarod
Re: Command Prompt Issues with Eclipse [message #1415546 is a reply to message #1415338] |
Tue, 02 September 2014 22:55  |
> Thanks in advance.
> -Jarod
You don't get a separate command prompt window when you run from
Eclipse. The Eclipse console is the command prompt window. You can
type your input into the Eclipse console.
FUDForum. Page generated in 0.03932 seconds
