Home » Modeling » Epsilon » Processing an Ecore-Based Model as a Graph
Processing an Ecore-Based Model as a Graph [message #1415196] Tue, 02 September 2014 05:41 Go to next message
I currently have a graphml model/muddle and an EOL program which processes this model. However, I would like to (minimally) modify my EOL program to process an Ecore-based version of my model. I am therefore looking to replace the code below with something that would perform the equivalent function but with an Ecore-based model:
var elements = myModel.muddle.elements;
var nodes = elements.select(e|e.type.eClass().name = "MuddleElementType");
var edges = elements.select(e|e.type.eClass().name = "LinkElementType");
for(e in edges)
if(e.Target = self && e.Source = x)
for (n in nodes
//process
Having looked at the Javadoc for EmfModel, I noticed the methods
getAllOfType, getAllOfKind, and allContents. I tried:
var elements = myModel.getAllOfKind("EObject");
var elements = myModel.allContents();
These lines of code only returned the "nodes", that is, the EReferences (edges) were not returned. Furthermore, var edges = myModel.getAllOfKind("EReference") returned zero elements.
Does anyone have any suggestions?
Even if it is possible to obtain a list of all EReferences in a model, is it then possible to obtain the source and target EObjects given an EReference (as shown in the code above)? It would appear to me that it is only possible to determine the target of an EReference from a given source EObject.
Tom
Re: Processing an Ecore-Based Model as a Graph [message #1415393 is a reply to message #1415196] Tue, 02 September 2014 13:27 Go to previous messageGo to next message
Hi Tom,
When querying a model that conforms to an Ecore metamodel X, you can only use names of EClasses in X as parametes of getAllOf*(). The "EReference" EClass belongs to Ecore.ecore itself (your model -- conforms to --> X.ecore -- conforms to --> Ecore.ecore), so it's two meta-levels up and has no instances in your model. Does this help?
Dimitris
Re: Processing an Ecore-Based Model as a Graph [message #1415687 is a reply to message #1415393] Wed, 03 September 2014 07:03 Go to previous messageGo to next message
Thanks for the explanation. Is the implication of this then that it is not possible to generate a list\collection of all of the references/edges in my model? So, as an example, if I have an ecore model with 10,000 model elements (nodes) and only two references\links (edges), to find the target element of those two links I would need to iterate through the list of 10,000 model elements calling eCrossReferences() on each node? Clearly, if possible, it would be far more efficient in this case to be able to obtain all edges (2) and iterate through them to find the target nodes.
Tom
Re: Processing an Ecore-Based Model as a Graph [message #1415701 is a reply to message #1415687] Wed, 03 September 2014 07:53 Go to previous messageGo to next message
Hi Tom,
In EMF, references are not first-class objects. For example, in [1] it is not possible to directly get all the "author" references, but you could get hold of the author of a particular book "b" (b.author), all Writers in the model (Writer.all), or all authors of all books (Book.all.author).
Dimitris
[1] https://www.eclipse.org/epsilon/doc/articles/reflective-emf-tutorial/
[Updated on: Fri, 05 September 2014 06:24] by Moderator
Re: Processing an Ecore-Based Model as a Graph [message #1415861 is a reply to message #1415701] Wed, 03 September 2014 17:12 Go to previous message
I understand,thanks Dimitris!
Tom
Previous Topic:Model visibility in ETL-guard
Next Topic:[ECL] Problems with recursive permutation of items in collections acc. to Fike algorithm
Current Time: Sat Jul 19 22:22:56 EDT 2025
Powered by FUDForum. Page generated in 0.04102 seconds
