Home » Modeling » UML2 » exception when creating genmodel (Juno)
exception when creating genmodel (Juno) [message #895742] Sun, 15 July 2012 11:23 Go to next message
I've recently moved to Juno (EMF 2.8.0.v20120606-0717, UML 4.0.0.v20120604-0919) and came across a strange behavior.
If I reload or re-generate some of my genmodels, I get the following exception when I hit "Finish" in the genmodel wizard. As far as I can see, this only happens if the models reference the UML metamodel. Any idea what might be causing this?
(The genmodel looks fine if I ignore this)
Joel
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:121)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1028)
at org.eclipse.emf.converter.ui.contribution.base.ModelConverterWizard.performFinish(ModelConverterWizard.java:240)
at org.eclipse.emf.importer.ui.contribution.base.ModelImporterWizard.performFinish(ModelImporterWizard.java:170)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at sun.reflect.GeneratedMethodAccessor54.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:492)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.core.runtime.CoreException: An error occurred while performing this operation.
at org.eclipse.emf.common.util.DiagnosticException.toCoreException(DiagnosticException.java:41)
at org.eclipse.emf.converter.ui.contribution.base.ModelConverterWizard$1.execute(ModelConverterWizard.java:229)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
... 58 more
Caused by: org.eclipse.emf.common.util.DiagnosticException: An error occurred while performing this operation.
at org.eclipse.emf.converter.ui.contribution.base.ModelConverterWizard$1.execute(ModelConverterWizard.java:228)
... 61 more
Caused by: java.io.IOException: PUT failed with HTTP response code 405
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl$1.close(URIHandlerImpl.java:123)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfChangedWithMemoryBuffer(ResourceImpl.java:1228)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:972)
at org.eclipse.emf.importer.ModelImporter.saveGenModelAndEPackages(ModelImporter.java:763)
at org.eclipse.emf.importer.ui.contribution.base.ModelImporterWizard.doPerformFinish(ModelImporterWizard.java:157)
at org.eclipse.emf.converter.ui.contribution.base.ModelConverterWizard$1.execute(ModelConverterWizard.java:222)
... 61 more
Re: exception when creating genmodel (Juno) [message #895749 is a reply to message #895742] Sun, 15 July 2012 13:24 Go to previous messageGo to next message
Joel,
I think this is the same as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=382637
On 15/07/2012 5:23 PM, Joel Greenyer wrote:
> Joel
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> at
> at
> at
> ... 58 more
> at
> ... 61 more
> at
> at
> at
> at
> at
> at
> ... 61 more
Re: exception when creating genmodel (Juno) [message #1411273 is a reply to message #895749] Fri, 22 August 2014 17:42 Go to previous messageGo to next message
Bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=382637 is marked as fixed, and I have not had the problem discussed in this thread in a while. However, now that I have installed Luna and UML2 5.0.0, it seems to be back. Is anyone else having this problem again?
Re: exception when creating genmodel (Juno) [message #1411409 is a reply to message #1411273] Sat, 23 August 2014 04:01 Go to previous messageGo to next message
Hi Ed
The original bug was a consequence of the UML 2.4.1 support separating
out a (Primitive)Types package and not ensuring that it was always
registered.
Similar problems occurred in the Luna run up with the UML 2.5 support.
However there is now a UMLResourcesUtil.init() that ensures that the
many required registrations occur. Any user/application that does not
call this is guaranteed to have major migration headaches.
Ed Willink
Re: exception when creating genmodel (Juno) [message #1411414 is a reply to message #1411409] Sat, 23 August 2014 04:18 Go to previous messageGo to next message
Some of the UML 2.4.1 problems were caused by being helpful; the new
Types model was hidden/auto-referenced so that migrating users did not
need to worry about it. This made the hidden package very irregular. I
think that it is now regular so perhaps you need to include
Types.genmodel in your used genmodels.
Ed Willink
On 23/08/2014 09:01, Ed Willink wrote:
> Hi Ed
> registered.
> Regards
> Ed Willink
Re: exception when creating genmodel (Juno) [message #1412205 is a reply to message #1411414] Mon, 25 August 2014 10:45 Go to previous messageGo to next message
Ed --
I do use UMLResourceUtil.init() when using the metamodel at runtime, but I am not sure that this is relevant to creating a genmodel.
And I did have Types.genmodel included as a used genmodel from before. However, when I tried to reload the ecore model into the genmodel under Luna, I got the old error again. I also get the error when I try to create a new genmodel. There does not seem to be any way to select Types to be used model during the genmodel dialog, but even trying to fix up the genmodel XMI by hand after the fact doesn't seem to work for me.
-- Ed
Re: exception when creating genmodel (Juno) [message #1412226 is a reply to message #1412205] Mon, 25 August 2014 11:54 Go to previous message
Hi Ed
Sounds like it needs a new Bugzilla.
Ed Willink
On 25/08/2014 15:45, Ed Seidewitz wrote:
> Ed --
> -- Ed
Previous Topic:ExportAllDiagrams/Model Validation very slow on Luna
Next Topic:defining a new data type
Current Time: Sun Jul 20 12:57:57 EDT 2025
Powered by FUDForum. Page generated in 0.04874 seconds
