Home » Modeling » TMF (Xtext) » Update 2.5.3 to 2.6.2 - ECollections.sort() Question
Update 2.5.3 to 2.6.2 - ECollections.sort() Question [message #1412046] Mon, 25 August 2014 02:48
Eclipse GuestFriend
Member
I'm updating my Xtext Project from 2.5.3 to 2.6.2. Now i've got a problem with my sorting quickfix. Before the update ECollections::sort() works fine.
After the update this happens:
Before quickfix:
AttributeList {
		TAttribute Date
		TAttribute Time
		TAttribute State
		LicenseNumber {
			Description ""
			Column LICENSE
			Type Number
After quickfix (xtext 2.5.3):
AttributeList {
		LicenseNumber {
			Description ""
			Column LICENSE
			Type Number
		TAttribut State
		TAttribut Date
		TAttribut Time
After quickfix (xtext 2.6.2):
AttributeList {
		LicenseNumber {
			Description ""
			Column LICENSE
			Type Number
	TAttribute StateTAttribute Date
		TAttribute Time
Grammar for the both attribut types:
Attribute:
	name=ValidID '{'
		('Description' beschreibung=STRING)?
		'Column' column=ValidID
		'Type' type=PersistenceType
TAttributeReference:
	('TAttribute' tAttribute=[TechnicalAttribute])
	'TAttribute' tAttribute=[TechnicalAttribute] '{'
		('Description' description=STRING)?
			('Column' column=ValidID)?
			('Type' type=PersistenceType)?
The quickfix implementation
@Fix(PersistenzXtendValidator::ISSUE_CODE_WRONG_ORDER)
	def fixWrongOrder(Issue issue, IssueResolutionAcceptor acceptor) {
		acceptor.accept(issue, "Sort", "Sort", null,
			[ element, context |
				val entitaet = element as BasisEntitaet
				ECollections::sort(entitaet.attribute, entitaetAttributComparator)
The Order is still correct, but the serialization failed. The attributes mixed together and the model is invalid.
Maybe someone has a hint why this could happen.
Previous Topic:How to test NatTable using swtbot?
Next Topic:How to implement efficient type inferrer/provider?
Current Time: Sun Jul 20 18:48:50 EDT 2025
Powered by FUDForum. Page generated in 0.04542 seconds
