exception when creating genmodel (Juno) [message #895742] |
Sun, 15 July 2012 11:23  |
I've recently moved to Juno (EMF 2.8.0.v20120606-0717, UML 4.0.0.v20120604-0919) and came across a strange behavior.
If I reload or re-generate some of my genmodels, I get the following exception when I hit "Finish" in the genmodel wizard. As far as I can see, this only happens if the models reference the UML metamodel. Any idea what might be causing this?
(The genmodel looks fine if I ignore this)
Joel
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:121)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1028)
at org.eclipse.emf.converter.ui.contribution.base.ModelConverterWizard.performFinish(ModelConverterWizard.java:240)
at org.eclipse.emf.importer.ui.contribution.base.ModelImporterWizard.performFinish(ModelImporterWizard.java:170)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at sun.reflect.GeneratedMethodAccessor54.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:492)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.core.runtime.CoreException: An error occurred while performing this operation.
at org.eclipse.emf.common.util.DiagnosticException.toCoreException(DiagnosticException.java:41)
at org.eclipse.emf.converter.ui.contribution.base.ModelConverterWizard$1.execute(ModelConverterWizard.java:229)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
... 58 more
Caused by: org.eclipse.emf.common.util.DiagnosticException: An error occurred while performing this operation.
at org.eclipse.emf.converter.ui.contribution.base.ModelConverterWizard$1.execute(ModelConverterWizard.java:228)
... 61 more
Caused by: java.io.IOException: PUT failed with HTTP response code 405
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl$1.close(URIHandlerImpl.java:123)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfChangedWithMemoryBuffer(ResourceImpl.java:1228)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:972)
at org.eclipse.emf.importer.ModelImporter.saveGenModelAndEPackages(ModelImporter.java:763)
at org.eclipse.emf.importer.ui.contribution.base.ModelImporterWizard.doPerformFinish(ModelImporterWizard.java:157)
at org.eclipse.emf.converter.ui.contribution.base.ModelConverterWizard$1.execute(ModelConverterWizard.java:222)
... 61 more
Re: exception when creating genmodel (Juno) [message #1412226 is a reply to message #1412205] |
Mon, 25 August 2014 11:54  |
Hi Ed
Sounds like it needs a new Bugzilla.
Ed Willink
On 25/08/2014 15:45, Ed Seidewitz wrote:
> Ed --
> I do use UMLResourceUtil.init() when using the metamodel at runtime, but
> I am not sure that this is relevant to creating a genmodel.
> And I did have Types.genmodel included as a used genmodel from before.
> However, when I tried to reload the ecore model into the genmodel under
> Luna, I got the old error again. I also get the error when I try to
> create a new genmodel. There does not seem to be any way to select Types
> to be used model during the genmodel dialog, but even trying to fix up
> the genmodel XMI by hand after the fact doesn't seem to work for me.
> -- Ed
FUDForum. Page generated in 0.26680 seconds
