Home » Eclipse Projects » e(fx)clipse » Embedding JavaFX in SWT E4 RCP application doesn't work(FXViewPart is empty and FXCanvas class can't even be found)
Embedding JavaFX in SWT E4 RCP application doesn't work [message #1411098] Fri, 22 August 2014 07:34 Go to next message
I have an E4 RCP application using SWT, built with Eclipse Luna and running on Debian 7.6 64-bit. My goal is to embed JavaFX into this application.
I downloaded JDK 8 from the Oracle site, unzipped it, provided the path to the -vm parameter in eclipse.ini, added it to the installed JREs in Eclipse and set it for my application plug-in and product.
I added e(fx)clipse from http://download.eclipse.org/efxclipse/updates-released/1.0.0/site to my Luna installation, selecting all items. I also added "RCP 3.x Target Platform" and "Target Platform" from http://download.eclipse.org/efxclipse/runtime-nightly/site to the target platform.
I added the following plug-ins to the dependencies:
  • org.eclipse.fx.ui.workbench3
  • org.eclipse.fx.javafx
And the following features to the product:
  • org.eclipse.fx.target.rcp.feature
  • org.eclipse.rcp
Based on e(fx)clipse tutorial no. 2, I added -Dosgi.framework.extensions=org.eclipse.fx.osgi to the VM arguments and the following part to my part stack:
import javafx.scene.Scene;
import javafx.scene.control.Button;
import javafx.scene.layout.BorderPane;
import org.eclipse.fx.ui.workbench3.FXViewPart;
public class JavaFxPart extends FXViewPart {
	private Button button;
	protected Scene createFxScene() {
		BorderPane pane = new BorderPane();
		button = new Button("test");
		pane.setCenter(button);
		return new Scene(pane);
	protected void setFxFocus() {
		button.requestFocus();
However, that part doesn't display anything. Debugging also shows that createFxScene is not entered.
Alternatively, I tried to use FXCanvas (wouldn't it be better anyway to use this instead of a view part based on E3?), but the class can't be found.
What am I doing wrong?
Re: Embedding JavaFX in SWT E4 RCP application doesn't work [message #1411138 is a reply to message #1411098] Fri, 22 August 2014 09:41 Go to previous messageGo to next message
On FXViewPart:
First of all is the application you develop a pure e4 application?
FXViewPart only makes sense in an Compat-e4 application.
On FXCanvas:
So did you added a package import for javafx.embedd.swt? Did you try
lauching with -Defxclipse.osgi.hook.debug=true to see if the adapter
hook is loaded?
On usage in pure e4+SWT:
In case you have a pure e4 application simply:
a) add
- org.eclipse.fx.ui.di.interopt
- org.eclipse.fx.javafx
- org.eclipse.fx.osgi
to your launch config
b) launch the application with -Defxclipse.osgi.hook.debug=true
c) Simply develop a pure JavaFX Part like this
public class TestFX {
@PostConstruct
public void init(BorderPane p) {
// write your javafx code
I would suggest to have the parts who are implemented in javafx in
an extra bundle which has NO swt dependency but only does package
imports for javafx!
Tom
Tom
> application.
> platform.
> org.eclipse.rcp
> Based on https://wiki.eclipse.org/Efxclipse/Tutorials/Tutorial2, I added
> @Override
> @Override
> found.
Re: Embedding JavaFX in SWT E4 RCP application doesn't work [message #1411139 is a reply to message #1411138] Fri, 22 August 2014 09:43 Go to previous messageGo to next message
one more note. On Linux JavaFX will only be loaded if your SWT is
running with Gtk2, JavaFX fails when SWT runs on Gtk3
-Defxclipse.osgi.hook.debug=true will spit out informations if this is
the case.
You need to force SWT to Gtk2 by setting SWT_GTK3=0 in your env.
Tom
On 22.08.14 15:41, Tom Schindl wrote:
> On FXViewPart:
> On FXCanvas:
> hook is loaded?
> a) add
> @PostConstruct
> imports for javafx!
> Tom
> Tom
>> application.
>> platform.
>> org.eclipse.rcp
>> @Override
>> @Override
>> found.
Re: Embedding JavaFX in SWT E4 RCP application doesn't work [message #1412167 is a reply to message #1411138] Mon, 25 August 2014 09:07 Go to previous message
Thanks for your hints, I found the root of the problem in the meantime:
Bundle-RequiredExecutionEnvironment in the manifest file was set to JavaSE-1.7. Only after setting it to JavaSE-1.8, jfxswt.jar has been added automatically to the application plug-in dependencies. This allowed me to finally use FXCanvas:
@PostConstruct
public void createControls(Composite parent) {
	final FXCanvas fxCanvas = new FXCanvas(parent, SWT.NONE) {
		public Point computeSize(int wHint, int hHint, boolean changed) {
			getScene().getWindow().sizeToScene();
			int width = (int) getScene().getWidth();
			int height = (int) getScene().getHeight();
			return new Point(width, height);
	javafx.scene.Group group = new javafx.scene.Group();
	final javafx.scene.control.Button jfxButton = new javafx.scene.control.Button("JFX Button");
	jfxButton.setStyle("-fx-background-color: linear-gradient(#ff5400, #be1d00); " + "-fx-background-radius: 30; " + "-fx-background-insets: 0; " + "-fx-text-fill: white;");
	group.getChildren().add(jfxButton);
	Scene scene = new Scene(group, Color.rgb(parent.getBackground().getRed(), parent.getBackground().getGreen(), parent.getBackground().getBlue()));
	fxCanvas.setScene(scene);
I'll comment on your reply in case other people with similar problems find this thread.
Yes, it's pure E4. That's why I asked about the usefulness of FXViewPart in this case. Thanks for the clarification, now I don't need to worry that this still doesn't work.
It was imported via the org.eclipse.fx.javafx plug-in, so I couldn't even add it to the Imported Packages list.
Did you try
hook is loaded?
I had tried launching with that VM argument before, but it didn't have any effect on the output. Now there are indeed messages from FXClassLoader etc.
a) add
org.eclipse.fx.osgi seems to be a fragment which I couldn't add to the dependencies. org.eclipse.fx.ui.di.interopt was not needed to make my FXCanvas example run.
@PostConstruct
imports for javafx!
Thanks, these are useful hints for future development of the application.
Good comment, I have to do this anyway for Eclipse Luna because otherwise the whole IDE wouldn't even start.
Previous Topic:Popups in FXCanvas do not disappear on focus lost events
Next Topic:Canvas is not a valid type
Current Time: Sun Jul 20 12:03:48 EDT 2025
Powered by FUDForum. Page generated in 0.05925 seconds
