Home » Eclipse Projects » Oomph » P2: CheckTrust -Workbench has not been created yet(P2 Director fails with Error "Workbench has not been created yet.")
P2: CheckTrust -Workbench has not been created yet [message #1411007] Fri, 22 August 2014 02:56 Go to next message
I encounter an strange behaviour when executing Oomph with a very simple setup. (It worked a few weeks back on an older Oomph version).
I am only building a product, so I check the "Skip project selection" box and run my product catalog. The product I am building is basically a copy of the "Eclipse Standard/SDK" defined in the Oomph product catalog.
When I run the product catalog like this everything works fine.
Now I add 1 more P2 director "JD Eclipse" (1 feature and 1 repository) That repository is locally hosted as there does not seem to be an online update site available (Update Site can be found via google by searching for "JD Eclipse" --> jd.benow.ca) (Sorry seems like I cannot yet use the direct link in this forum)
When I run this product catalog now I get the following exception during the P2 director execution:
[08:24:31] An error was detected while performing the engine operation and the changes are being rolled back. See the log for details.
[08:24:31] ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred during the org.eclipse.equinox.internal.p2.engine.phases.CheckTrust phase.
  at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:196)
  at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$1.commit(ProfileTransactionImpl.java:420)
  at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:298)
  at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:691)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:2428)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2384)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2374)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2314)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$7.run(ProgressPage.java:377)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9$1.run(ProgressPage.java:454)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
  ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=c__Temp_OomphNew_Test_02_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.CheckTrust, operand=, action=).
  ERROR: org.eclipse.equinox.p2.engine code=0 Failed to execute runnable (java.lang.IllegalStateException: Workbench has not been created yet.)
  org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.IllegalStateException: Workbench has not been created yet.)
    at org.eclipse.swt.SWT.error(SWT.java:4441)
    at org.eclipse.swt.SWT.error(SWT.java:4356)
    at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:209)
    at org.eclipse.swt.widgets.Display.syncExec(Display.java:4734)
    at org.eclipse.oomph.p2.internal.ui.P2ServiceUI.getTrustInfo(P2ServiceUI.java:149)
    at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.getTrustInfo(ProfileTransactionImpl.java:525)
    at org.eclipse.equinox.internal.p2.engine.phases.CertificateChecker.checkCertificates(CertificateChecker.java:152)
    at org.eclipse.equinox.internal.p2.engine.phases.CertificateChecker.start(CertificateChecker.java:54)
    at org.eclipse.equinox.internal.p2.engine.phases.CheckTrust.completePhase(CheckTrust.java:50)
    at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:251)
    at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:101)
    at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
    at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:75)
    at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
    at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:41)
    at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$1.commit(ProfileTransactionImpl.java:419)
  Caused by: java.lang.IllegalStateException: Workbench has not been created yet.
    at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:93)
    at org.eclipse.ui.dialogs.ListSelectionDialog.configureShell(ListSelectionDialog.java:159)
    at org.eclipse.jface.window.Window.createShell(Window.java:507)
    at org.eclipse.jface.window.Window.create(Window.java:434)
    at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1101)
    at org.eclipse.jface.window.Window.open(Window.java:797)
    at org.eclipse.oomph.p2.internal.ui.P2ServiceUI$3.run(P2ServiceUI.java:156)
    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:136)
    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4147)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3764)
    at org.eclipse.jface.window.Window.runEventLoop(Window.java:832)
    at org.eclipse.jface.window.Window.open(Window.java:808)
    at org.eclipse.oomph.setup.internal.installer.InstallerApplication.start(InstallerApplication.java:84)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
    ... 1 more
When I use this JD-Eclipse update site in an existing Eclipse installation it works perfectly.
Does anybody know why this is happening, or what that error stack actually means?
I attached my product catalog to this post and inserted the link to this update site download above, for those who want to try it themselfs. Please make sure you update the link to the JD-Eclipse repository inside the product catalog.
Re: P2: CheckTrust -Workbench has not been created yet [message #1411132 is a reply to message #1411007] Fri, 22 August 2014 09:20 Go to previous messageGo to next message
Just found out that the same behviour applies when using JRebel. Might be easier to reproduce:
Requirements:
org.zeroturnaround.eclipse.feature.feature.group
org.zeroturnaround.eclipse.wtp.feature.feature.group
org.zeroturnaround.eclipse.m2e.feature.feature.group
Re: P2: CheckTrust -Workbench has not been created yet [message #1411151 is a reply to message #1411132] Fri, 22 August 2014 10:16 Go to previous messageGo to next message
Sascha,
Yes, that's https://bugs.eclipse.org/bugs/show_bug.cgi?id=442351 and
I've figured out the cause. Personally this dialog has never tried to
come up for me, but when I fake it, I get the same exception.
Essentially the problem is it's trying to add the platform's help
service and that's no available. So I will bypass that part of
configuring the shell and all should be good. You can monitor that
bugzilla and try again when the fix is there shortly.
> Requirements:
Re: P2: CheckTrust -Workbench has not been created yet [message #1411157 is a reply to message #1411151] Fri, 22 August 2014 10:35 Go to previous message
Ed,
that is just the answer I was hoping for.
Thanks for the quick response
Previous Topic:Project Selection misses "IDE for DSL developers"
Next Topic:No workspace created when "skip project selection" is used
Current Time: Sat Jul 19 21:15:00 EDT 2025
Powered by FUDForum. Page generated in 0.03908 seconds
