Home » Eclipse Projects » Eclipse 4 » Workbench not persisted under Mac
Workbench not persisted under Mac [message #1407727] Wed, 13 August 2014 05:55 Go to next message
Hey guys,
I have a very basic E4 application (3-column layout, empty parts) which
starts under all platforms (Win 7 64, Ubuntu 14.04, Mac OS X) and looks
the same.
However, among some DnD problems I noticed that the workbench is not
persisted under Mac OS X. The org.eclipse.e4.ui.workbench folder is not
created under the .metadata/.plugins directory and so there is no
workbench.xmi file.
In my arguments I have -persistState and this works under Windows and
Ubuntu. I already tried to use a different folder with -data flag which
resulted in an IllegalStateException on startup. I also tried setting
full rights on group level to the .plugins folder (just in case the
application isn't allowed to create a folder there) but this didn't help
either.
I had a look at eclipse Kepler configuration and it seems like
persisting the workbench is working there. The o.e.e4.ui.workbench
folder exists and there is a workbench.xmi file in it which gets updated
on shutdown of eclipse Kepler.
Are there any special settings I need to set on the Mac or in my
application in order to make workbench persistence work or is this a bug?
Thanks in advance
Marina Knieling
Re: Workbench not persisted under Mac [message #1407846 is a reply to message #1407727] Wed, 13 August 2014 11:46 Go to previous messageGo to next message
There are no special settings required for the Mac. Look at your <product>.ini file and the configuration/config.ini and verify that the arguments and settings are what you expect. And look at your .product definition file to ensure you haven't set some platform-specific settings there.
We'll need more detail (e.g., configuration information above, plus about the IllegalSateException from -data). But before you do, try using the Eclipse 4 Model Editor (which includes the Eclipse 4 Tools) to create a dummy application (Eclipse 4 > Eclipse 4 Application Project) and verify that it doesn't work either.
Note: The directory should be org.eclipse.e4.workbench, not .ui.workbench.
Brian.
Re: Workbench not persisted under Mac [message #1408149 is a reply to message #1407846] Thu, 14 August 2014 06:54 Go to previous messageGo to next message
Hi Brian,
1) There aren't any platform-specific settings there. I just switched
-clearPersistedState for -persistState in the "All Platforms" tab. The
macosx launching tab includes the -XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts for VM Arguments, but this
seems to be ok.
The <product>.ini file includes the mentioned -persistState and the
other two arguments preceded by -vmargs, so this looks ok. config.ini
also looks correct.
Note: I'm using the delta pack to compile for Mac.
2) I created the dummy application with sample content (on Kepler on Mac
this time) and persistence worked there (out of Eclipse and exported as
product as well).
I customized some parts of the application:
1) I wrote my own Menu and MenuItem renderer. Any chance I did something
wrong there that might suppress workbench persistence under mac?
2) In addition there is a fragment.e4xmi that contributes a whole
perspective to the model.
3) I've overwritten dndaddon and minmaxaddon (copied the original code
and made some minor changes).
Everything else is 'standard' e4 and I can't think of anything that
might be the source of evil ;-)
Concerning the IllegalStateException: I'll switch to the Mac and then
copy the stacktrace here (I'm under Windows right now).
Marina
> settings there.
> Brian.
Re: Workbench not persisted under Mac [message #1408199 is a reply to message #1408149] Thu, 14 August 2014 09:26 Go to previous messageGo to next message
It sounds like an exception might be eaten. I'd suggest you try attaching Eclipse to your running instance and put a breakpoint in E4Application#saveModel(). Try stepping through and see what's happening.
Brian.
Re: Workbench not persisted under Mac [message #1408516 is a reply to message #1408199] Fri, 15 August 2014 04:57 Go to previous messageGo to next message
Hi Brian,
it seems like saveAndRestore variable in ResourceHandler is false, although -persistState is set in <product>.ini.
Is there any way I can see how the arguments are read and how/where they are injected in the ResourceHandler?
BTW: target platform is Luna
<product>.ini looks like this ( at the moment with the debug flags set):
-startup
../../../plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
--launcher.library
../../../plugins/org.eclipse.equinox.launcher.cocoa.macosx.x86_64_1.1.200.v20140603-1326
-persistState
-vmargs
-Xdebug
-agentlib:jdwp=transport=dt_socket,server=y,address=8000
Any ideas on what might have gone wrong?
Marina
Re: Workbench not persisted under Mac [message #1408534 is a reply to message #1408516] Fri, 15 August 2014 05:51 Go to previous messageGo to next message
Hi again,
a colleague found out that setting -DpersistState=true in the product
file in the VM arguments works. This flag seems to default to true under
Windows but not under Mac. Not setting -persistState (in the normal way)
persists the workbench under Windows anyways, but not under Mac.
Is this a known bug or a feature? :-)
Marina
On 15.08.2014 10:57, Marina Knieling wrote:
> Hi Brian,
> -startup
> --launcher.library
> -persistState
> -vmargs
> -Xdebug
> Marina
Re: Workbench not persisted under Mac [message #1408674 is a reply to message #1408534] Fri, 15 August 2014 15:02 Go to previous messageGo to next message
Marina Knieling wrote on Fri, 15 August 2014 05:51
-persistState takes an argument, true or false. That you're not providing one means that the behaviour is undefined, and likely false. See the code in E4Application#loadApplicationModel() around line 389:
// Save and restore
boolean saveAndRestore;
String value = getArgValue(IWorkbench.PERSIST_STATE, appContext, false);
saveAndRestore = value == null || Boolean.parseBoolean(value);
I don't know why your model was persisting under Windows -- that's more of a bug!
Brian.
Re: Workbench not persisted under Mac [message #1409511 is a reply to message #1408674] Mon, 18 August 2014 05:36 Go to previous message
Didn't know that. Is this documented somewhere? As -clearPersistedState
doesn't take an argument, I thought it's the same with -persistState.
Thanks for your help, it works now.
Previous Topic:Does e4 use a different SelectionService?
Next Topic:Running exported E4 app outside of it's directory causes widgets lacking
Current Time: Sun Jul 20 14:00:57 EDT 2025
Powered by FUDForum. Page generated in 0.04189 seconds
