EMF EObject with JPA [message #1407776] |
Wed, 13 August 2014 08:28  |
Hey guys,
is it possible to annotate EObjects with JPA annotations? We're working
in a JBoss environment and need to use EJB and JPA but we'd like to make
use of the integrated undo/redo mechanism of the EMF EObjects. Using
Texo on the server side and EMF on the client side as described in this
thread (http://www.eclipse.org/forums/index.php/t/199296/) was my first
idea, but serializing/deserializing the model and sending it back and
forth is no real option (a similar approach has been discarded in our
company not so long ago).
So a colleague first had the idea to simply implement EObject but I
think EMF is more than just EObject (thinking of the Package and
Reflective API).
Are there any other ideas on this use case or can I just annotate my
Thanks for any hints or ideas on that
Marina Knieling
Re: EMF EObject with JPA [message #1407884 is a reply to message #1407776] |
Wed, 13 August 2014 13:53   |
Hi Marina,
Directly annotating EObjects won't work because EMF has its own list implementations, often JPA solutions also have
their own list implementations which collide with what EMF does/needs.
Some options:
You can try the Teneo project but it only works with Hibernate. https://wiki.eclipse.org/Teneo
Texo can also be used directly in your webcontainer, so no need to go through json serialization afaics. But there is a
conversion from EObjects to Texo objects and back, it makes use of the EMF proxy concept so it is somewhat transparent
for the EMF-using-code.
gr. Martin
On 13-08-14 14:28, Marina Knieling wrote:
> Hey guys,
> is it possible to annotate EObjects with JPA annotations? We're working in a JBoss environment and need to use EJB and
> JPA but we'd like to make use of the integrated undo/redo mechanism of the EMF EObjects. Using Texo on the server side
> and EMF on the client side as described in this thread (http://www.eclipse.org/forums/index.php/t/199296/) was my first
> idea, but serializing/deserializing the model and sending it back and forth is no real option (a similar approach has
> been discarded in our company not so long ago).
> So a colleague first had the idea to simply implement EObject but I think EMF is more than just EObject (thinking of the
> Package and Reflective API).
> Are there any other ideas on this use case or can I just annotate my EObjects with JPA annotations?
> Marina Knieling
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: EMF EObject with JPA [message #1408107 is a reply to message #1407884] |
Thu, 14 August 2014 04:41   |
Hi Martin,
in our environment we're using Hibernate as the JPA implementation. I've
worked with Teneo before, but only for a small project and not in
combination with any application server and so I wasn't aware of the
possibility to annotate models with JPA annotations.
Does that mean that I can 'simply' create the ecore model, add
annotations for JPA via EAnnotations (e.g. specifying column names) and
then this is equal/similar to writing POJOs and annotating them
manually? With the only difference that I now have EObjects instead of
normal Objects?
That sounds like a solution to me.
Thanks, Marina
On 13.08.2014 19:53, Martin Taal wrote:
> Hi Marina,
> implementations, often JPA solutions also have their own list
> Some options:
> through json serialization afaics. But there is a conversion from
> so it is somewhat transparent for the EMF-using-code.
> gr. Martin
>> Hey guys,
>> Marina Knieling
Re: EMF EObject with JPA [message #1408253 is a reply to message #1408107] |
Thu, 14 August 2014 11:46  |
Hey Marina,
Yes that's indeed how it works. Teneo only depends on a few of the EMF jars (and Hibernate):
https://wiki.eclipse.org/Teneo/Hibernate/Download_and_Install#Usage_in_a_Web_Container_-_Maven
gr. Martin
On 14-08-14 10:41, Marina Knieling wrote:
> Hi Martin,
> in our environment we're using Hibernate as the JPA implementation. I've worked with Teneo before, but only for a small
> project and not in combination with any application server and so I wasn't aware of the possibility to annotate models
> Does that mean that I can 'simply' create the ecore model, add annotations for JPA via EAnnotations (e.g. specifying
> column names) and then this is equal/similar to writing POJOs and annotating them manually? With the only difference
> that I now have EObjects instead of normal Objects?
> Thanks, Marina
>> Hi Marina,
>> Some options:
>> gr. Martin
>>> Hey guys,
>>> Marina Knieling
The Netherlands
FUDForum. Page generated in 0.03798 seconds
