Home » Eclipse Projects » Oomph » using variables and importing projects not working
using variables and importing projects not working [message #1405150] |
Wed, 06 August 2014 13:59  |
Ok now in the right forum
I'm grokking using the targlet to specify what I want to work with instead of a project set file, and I agree that is an improvement. However, I'm still stuck on the git clone and the import project task.
We work with multiple git repositories so what I have done is set up a variable for a "common" git clone location, and all of the git clone tasks reference this variable. Oddly, the variable does NOT show up on the screen as something I can fill in when I'm running the installation. If I omit the variable from my setup file, then it will show up as an undefined variable to fill out. I have tried putting the variable at the project level in the setup file, and in the branch where my git clone commands are, to no avail.
Here is my variable definition:
<setupTask
xsi:type="setup:VariableTask"
id=""
name="gitpath"
value=""
defaultValue="${workspace.location/piffle}"
label="Git Path for cloning">
<description>Path for the checkout of multiple git repositories</description>
</setupTask>
Second problem -- nothing we seem to do supports project import. Right now we have a Projects Import task which has a number of Source Locator entries defined, and despite the fact that the source exists there, nothing is imported. We have the same source locators defined in the targlet. I have a hunch that some of the issue is around not being able to discover the top-level product project in the targlet?
Thanks so much for your help
Tamar
<setupTask
xsi:type="setup.targlets:TargletTask"
id="verve.knrover.rapid.targlet">
<targlet
name="${scope.project.label}"
activeRepositoryList="">
<requirement
id="gov.nasa.arc.verve.rcp.knrover.rapid.product"
versionRange="1.0.0.qualifier"
optional="true"/>
<sourceLocator
rootFolder="${git.clone.verve-knrover-rapid.location}"
locateNestedProjects="true"/>
<sourceLocator
rootFolder="${git.clone.verve-rcp.location}"
<sourceLocator
rootFolder="${git.clone.irg-plan.location}"
<sourceLocator
rootFolder="${git.clone.verve-robot.location}"
<sourceLocator
rootFolder="${git.clone.rapid.location}"
<sourceLocator
rootFolder="${git.clone.irg-rapid.location}"
<repositoryList
name="Dependencies">
<repository
url="http://download.eclipse.org/releases/luna"/>
<repository
url="http://download.eclipse.org/tools/orbit/downloads/drops/R20140114142710/repository"/>
<repository
url="https://secret/p2_third_party/"/>
<repository
url="https://secret/thirdparty/.meta/p2"/>
</repositoryList>
<repositoryList>
<repository
url="${git.clone.verve-knrover-rapid.location|uri}"/>
<repository
url="${git.clone.verve-rcp.location|uri}"/>
<repository
url="${git.clone.irg-plan.location|uri}"/>
<repository
url="${git.clone.verve-robot.location|uri}"/>
<repository
url="${git.clone.rapid.location|uri}"/>
<repository
url="${git.clone.irg-rapid.location|uri}"/>
</repositoryList>
</targlet>
</setupTask>
<setupTask
xsi:type="projects:ProjectsImportTask">
<sourceLocator
locateNestedProjects="true">
<predicate
xsi:type="predicates:OrPredicate">
<operand
xsi:type="predicates:NamePredicate"
pattern=".*knrover.*"/>
<operand
pattern=".*mvp.*"/>
<operand
pattern="gov.nasa.arc.verve.rcp"/>
<operand
pattern=".*ide.*"/>
<operand
pattern=".*common.*"/>
</predicate>
</sourceLocator>
<sourceLocator
<predicate
xsi:type="predicates:NotPredicate">
<operand
pattern=".*spheres.*"/>
</predicate>
</sourceLocator>
<sourceLocator
<sourceLocator
<predicate
<operand
pattern=".*v2.*"/>
<operand
pattern=".*idl.*"/>
<operand
pattern="gov.nasa.rapid.util"/>
<operand
pattern="gov.nasa.rapid.rcp.log.player"/>
</predicate>
</sourceLocator>
<sourceLocator
</setupTask>
Re: using variables and importing projects not working [message #1405160 is a reply to message #1405150] |
Wed, 06 August 2014 14:20   |
Tamar,
Comments below.
On 06/08/2014 7:59 PM, Tamar Cohen wrote:
> Ok now in the right forum :)
Yep, but a little more work to get right the first time.
Hmmm, there's a rule for where git clones should go. You should use
that approach. Look in the Eclipse.org catalog how all the projects
there are authored.
> no avail.
> <setupTask
> id=""
> name="gitpath"
> value=""
> </setupTask>
Best you not define a variable for this. Look at the git clone tasks
in the catalog. Note that each define an ID for the task, which induces
variables. I.e., if the ID of the GitClone task is x, then the variable
x.location will be available automatically and will contain the value of
the task's location.
The targlet task will do that, assuming you've specified a source
locator that can really find source projects.
Maybe have a look at the EGit.setup; it involves two clones and it's
targlet task functions correctly. Note that you can open the
index/catalogs from the tool bar icon...
> Tamar
> <setupTask
> <targlet
> <requirement
Probably best you don't specify a range like this, and if you really
wanted a range better it be [1.0.0,1.0.1)....
> optional="true"/>
> <sourceLocator
> <sourceLocator
> <sourceLocator
> <sourceLocator
> <sourceLocator
> <sourceLocator
> <repositoryList
> <repository
> <repository
> <repository
> <repository
> </repositoryList>
> <repositoryList>
> <repository
No, a clone is not a p2 repo...
> <repository
> <repository
> <repository
> <repository
> <repository
> </repositoryList>
> </targlet>
> </setupTask>
> <setupTask
You should only need this for a project that isn't a plugin or feature
(or for which you don't desire to resolve all it's dependencies in the TP).
> <sourceLocator
> <predicate
> <operand
> <operand
> pattern=".*mvp.*"/>
> <operand
> <operand
> pattern=".*ide.*"/>
> <operand
> </predicate>
> </sourceLocator>
> <sourceLocator
> <predicate
> <operand
> </predicate>
> </sourceLocator>
> <sourceLocator
> <sourceLocator
> <predicate
> <operand
> pattern=".*v2.*"/>
> <operand
> pattern=".*idl.*"/>
> <operand
> <operand
> </predicate>
> </sourceLocator>
> <sourceLocator
> </setupTask>
Re: using variables and importing projects not working [message #1405187 is a reply to message #1405160] |
Wed, 06 August 2014 16:02   |
Ok I've realized that my branch import task needed to be within the targlet; with that set up the repositories are actually cloned and visible, and project import works when the import projects task is after the targlet task within the branch import task.
Ed Merks wrote on Wed, 06 August 2014 14:20
>there are authored.
Thanks, I'm taking a look and will revise. What I want to do is have a common root directory where all of the child git repositories will be cloned.
Yes, and I am already using those, and they work perfectly. It's the root path of them that I want to make easy to change.
We've removed all of the requirements since we want to explicitly import a subset of the projects in the git repositories we have cloned. Now these projects DO show up in our workspace, but they don't actually compile because the target platform is missing contents from our p2 update sites.
> <repositoryList
> <repository
> <repository
> <repository
> <repository
> </repositoryList>
> <repositoryList>
> <repository
What I was trying to do here was to set up dependencies for our target platform to pull plugins that we have already built and are hosting at our internal p2 update sites, which was why they were listed in "dependencies". I think we need to flesh out the target platform? Or should we be replicating that in the targlet?
> <setupTask
Yes, the latter is the case.
Thanks as always for your help!
Tamar
Re: using variables and importing projects not working [message #1405203 is a reply to message #1405187] |
Wed, 06 August 2014 16:48   |
So another thing I'm noticing is that when I include a "requirement" in my targlet, no matter what I put for the version (0.0.0, or a version range as you suggested, or 1.0.0.qualifier which is the current version), it is NOT FOUND. This should be found in two places, one in my p2 update site, and the other in the source within one of the git repositories, and I have verified that it's there.
Another issue is that when I explicitly say which projects to import, they are imported under "Other Projects" which is a bit weird. Really what I want is a subset of the projects that are in the git repositories to be imported into the workspace, and I want some plugins that are defined in our p2 update sites to be installed into the target platform.
thanks
Tamar
Re: using variables and importing projects not working [message #1405334 is a reply to message #1405203] |
Thu, 07 August 2014 01:49   |
Tamar,
Comments below.
One thing to keep in mind here is that if feature's ID in the
feature.xml is x, it's IU ID is x.feature.group.
Can that subset be defined as, for example, "this feature an all its
dependencies"?
The latest implementation of the targlet task will, for every workspace
project it resolves, also try to resolve a compatible binary version in
the TP, i.e., i.e., if IU with ID abc and version x.y.z.qualifier is
resolved into the workspace, if there is an IU with ID abc and version
matching the range [x.y.z,x.y.z+1) in some p2 repo, that will also end
up in the TP (with the idea that you could close the project
corresponding to abc in the workspace and then the version from the TP
will be used instead).
> thanks
> Tamar
Re: using variables and importing projects not working [message #1405735 is a reply to message #1405645] |
Fri, 08 August 2014 00:19   |
Hi Tamar,
Comments below...
Cheers
/Eike
http://www.esc-net.de
Am 07.08.2014 um 23:41 schrieb Tamar Cohen:
> Thanks Ed.
> I've now been referencing the latest egit.setup file which is helpful.
> I have made some progress and done the following:
> -updated my feature id to correctly reflect the installable unit
> -remove version of that feature entirely
> -removed the repository list that was duplicating the git repositories from within the targlet
> I realized that our infrastructure was still building against Kepler (DOH!) so when I was trying to do a Luna install
> the dependencies were finding only versions on our P2 update site that were requiring versions in Kepler, not in
> Luna. So I did a test install with Kepler instead of Luna and had some more success.
> With the above changes, it DOES actually find the main feature and its dependencies from our P2 update sites, source
> repositories and Kepler's p2 update sites, which is great!
> Unfortunately, it STILL does not show any projects in my workspace nor does it show any git repositories as imported.
> I can get projects in my workspace in the "Other Projects" folder if I have the explicit Projects Import but now I
> understand I should not need that at all.
> I'm also still confused as to what belongs in the P2 Director area at the top of my setup (just references to eclipse
> p2 update sites?)
The P2 Director tasks install (or update) tools into your *host* IDE.
> and what belongs in the RepositoryList within my targlet.
The Targlet task installs (or updates) targlets into the targlet container of your target platform. These targlets
contribute binary installable units (features and plugins) from their p2 repositories and/or source projects from their
source locators. If everything is configured correctly your source projects are compiled against your target platform
and the result can be launched as a *runtime* IDE or exported as a product.
> Right now they both contain the same things and I can't find any documentation clarifying what should be where.
That's probably less common, but I've seen people adding their tools to their target platform, so that they're available
inruntime launches, too.
Cheers
/Eike
Re: using variables and importing projects not working [message #1405740 is a reply to message #1405686] |
Fri, 08 August 2014 00:32  |
Am 08.08.2014 um 02:39 schrieb Tamar Cohen:
> So I think the tycho m2e support I need is actually a Maven plugin and not an Eclipse plugin -- but when I try to add
> a new child which is a Maven Import, my Eclipse that I'm using to edit the Setup file just goes into its own Setup
> loop where it tries to install / update something, restarts, and yet still after that I cannot add a Maven Import.
I suspect you refer to our meta model discovery that applies to your setup authoring IDE. Note that when you install an
IDE with Oomph only those tasks (i.e. the code plugins) are installed that are actually in the list of needed tasks for
that installation. E.g., the Maven Import tasks is not installed if the setup models for that IDE don't contain a Maven
Import task. That's cool for normal Oomph users because their IDE isn't cluttered with unneeded functionality. But
authors of the setup models may want to add new tasks to their models. And that's where our discovery mechanism kicks
in: The New Child menu of the setup model editor offers all tasks and elements that are registered in our global index
and, when you happen to select one of those, they get installed on demand. That's the extra setup cycle you're
observing. After that cycle (which includes an automatic restart) you can actually use the task in your setup model.
Cheers
/Eike
Current Time: Sat Jul 19 05:51:39 EDT 2025
Powered by FUDForum. Page generated in 0.24814 seconds
