Home » Modeling » EMF » Filtering Attributes
Filtering Attributes [message #1404787] Tue, 05 August 2014 14:43 Go to next message
Our current model contains bound attributes at the abstract class level (see attached diagram) and the concrete classes are displaying on the pallet so user can create instances by dropping them onto a diagram editor. Our tool has 2 type of diagrams editors (pattern diagram and argument diagram). However, we would like the bounds properties only to be displayed on the pattern diagrams. Besides that, the links behavior/meaning is exactly the same.
So, can I use EMF annotations to filter them out or will it be better split the links into two different types (e.g. PatternLink -> Link and ArgumentLink -> Link)
  • Attachment: Links.png
    (Size: 34.24KB, Downloaded 176 times)
Re: Filtering Attributes [message #1404792 is a reply to message #1404787] Tue, 05 August 2014 15:07 Go to previous messageGo to next message
Al,
Comments below.
Is this a GMF question? If so, it's likely better to ask on the GMF
newsgroup...
Re: Filtering Attributes [message #1404793 is a reply to message #1404792] Tue, 05 August 2014 15:31 Go to previous messageGo to next message
Hi Ed,
No, we are not using GMF. Let's say I am extending to type of EMF editors (forget about the pallet) and I want to filter attributes on the properties view based on the type of editor they EMF elements are being instantiated, can I used EMF annotations to accomplish that or or will it be better to split the links into two different types (e.g. PatternLink -> Link and ArgumentLink -> Link)?
TIA
Re: Filtering Attributes [message #1404884 is a reply to message #1404793] Wed, 06 August 2014 00:34 Go to previous messageGo to next message
Al,
Comments below.
On 05/08/2014 9:31 PM, Al B wrote:
> Hi Ed,
No, you can't control that with annotations. Which properties are
displayed can be control from the GenFeature, i.e., you can set Property
Type to None. But that's an all or nothing decision for that type of
object. In the end, the item providers themselves determine which
properties are displayed, so you could specialize
LinkItemProvider.getPropertyDescriptors such that whether or not it
returns those properties or not is conditional. You might make the
condition use some interface implemented by the adapterFactory (visible
as a protected member) to determine whether to return those property
descriptors, and then in one context (likely by default) you can show
them, and in another, you create a derived factory that specified you
don't want those extra properties, and use that factory instead when you
don't want them.
> TIA
Re: Filtering Attributes [message #1405189 is a reply to message #1404884] Wed, 06 August 2014 16:03 Go to previous message
Thanks Ed. You put me in the right track. Cheers!
Previous Topic:Array of references in model
Next Topic:Refresh View Programmatically
Current Time: Sat Jul 19 11:04:32 EDT 2025
Powered by FUDForum. Page generated in 0.24974 seconds
