Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Errors in UI project
[Acceleo] Errors in UI project [message #1404789] Tue, 05 August 2014 14:55
Dear all,
I generated an UI project from a very simple Acceleo project containing a single template. The resulting UI project contains several errors (which prevent its usage as a plugin) in the doGenerate method of the GenerateAll.java class (common package).
org.eclipse.acceleo.test.common.Services gen1 = new org.eclipse.acceleo.test.common.Services(model, targetFolder.getLocation().toFile(), arguments);
The line above is issuing the message: "The constructor Services(EObject, File, List<capture#4-of ? extends Object>) is undefined".
gen1.setGenerationID(generationID);
This one produces: "The method setGenerationID(String) is undefined for the type Service".
gen1.doGenerate(BasicMonitor.toMonitor(monitor));
And this recursive call also fails: "The method setGenerationID(String) is undefined for the type Services".
Any hints how to solve this issue are welcome. Thank you.
Previous Topic:Outdated Acceleo update site addresses
Next Topic:generating code for the multivalue attribute
Current Time: Sun Jul 20 12:36:18 EDT 2025
Powered by FUDForum. Page generated in 0.24765 seconds
