Home » Modeling » Papyrus » Creating models (uml,notation and di) programatically tutorial
Creating models (uml,notation and di) programatically tutorial [message #1404359] |
Thu, 31 July 2014 09:46  |
I'm trying to create some models by programming in Eclipse modelling tools, and I would like to view them in papyrus. Is there any tutorial or code snippet for creating di models? (Specially sysml models)
PS: I'm a beginner but I already see those topics (and the uml2 tools getting started):
www.eclipse.org/forums/index.php/m/1404122/
www.eclipse.org/forums/index.php/t/781914/
Any help is appreciated.
Thanks in advance,
Alexandre
Re: Creating models (uml,notation and di) programatically tutorial [message #1424271 is a reply to message #1404359] |
Mon, 15 September 2014 14:54   |
Hi!
I'm also trying with this. After lots of search on this forum and in the papyrus repository:
eclipse.googlesource.com/papyrus/org.eclipse.papyrus/+/master
I've managed to build up an eclipse plugin that creates a papyrus project, inserts an existing .uml file, creates the Class Diagrams and drops the Classes on the diagrams.
I think the two links that you found are the best helps.
Here is a code, that creates a papyrus model
(path is a string and stands for Projectname/Modelname e.g. MyPapyrusProject/mypapyrusmodel, where you have a folder MyPapyrusProject with the 3 files: mypapyrusmodel.uml, mypapyrusmodel.di, mypapyrusmodel.notation )
I'm not saying that it is the best way but works
ModelSet modelSet = new ModelSet();
ModelsReader reader = new ModelsReader(); //Standard ModelsReader for Di + UML + Notation
reader.readModel(modelSet);
String sourceUmlPath = "C:\\uml.uml";
String diFilePath = path+".di";
String umlFilePath = path+".uml";
URI diFileURI = URI.createFileURI(diFilePath);
URI umlFileURI = URI.createFileURI(umlFilePath);
URI diPResURI = URI.createPlatformResourceURI(diFilePath, true);
URI umlPResURI = URI.createPlatformResourceURI(umlFilePath, true);
URI resolvedFile = CommonPlugin.resolve(diFileURI);
IFile ifile = ResourcesPlugin.getWorkspace().getRoot().getFile(new Path(resolvedFile.toFileString()));
modelSet.createModels(diPResURI);
ServicesRegistry registry = new ExtensionServicesRegistry(org.eclipse.papyrus.infra.core.Activator.PLUGIN_ID);
try {
registry.add(ModelSet.class, Integer.MAX_VALUE, modelSet);
registry.startRegistry();
} catch (ServiceException ex) {
//Ignore
modelSet.save(new NullProgressMonitor());
modelSet.loadModels(umlPResURI);
URI UmlFileResURI = CommonPlugin.resolve(umlFileURI);
IFile UmlFile = ResourcesPlugin.getWorkspace().getRoot().getFile(new Path(UmlFileResURI.toFileString()));
InputStream is = new FileInputStream(sourceUmlPath);
UmlFile.setContents(is, true, false, new NullProgressMonitor());
IModelCreationCommand creationCommand = new CreateUMLModelCommand();
creationCommand.createModel(modelSet);
Re: Creating models (uml,notation and di) programatically tutorial [message #1494848 is a reply to message #1451154] |
Mon, 01 December 2014 15:20   |
Hello Alexandre,
first of all the 3 files don't need to be created. These files will be created as the ModelSet.save() function is called.
For the imports: In my code I use the followings:
import java.io.File;
import java.io.FileInputStream;
import java.io.InputStream;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.core.runtime.Path;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.papyrus.infra.core.editor.IMultiDiagramEditor;
import org.eclipse.papyrus.infra.core.extension.commands.IModelCreationCommand;
import org.eclipse.papyrus.infra.core.resource.ModelSet;
import org.eclipse.papyrus.infra.core.resource.ModelsReader;
import org.eclipse.papyrus.infra.core.services.ExtensionServicesRegistry;
import org.eclipse.papyrus.infra.core.services.ServiceException;
import org.eclipse.papyrus.infra.core.services.ServicesRegistry;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IWorkbenchPage;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.IWorkbenchWindowActionDelegate;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.PlatformUI;
(I'm not sure that all of them are necessary)
For debugging I think these imports will be enough. But if you want to export your plugin you have to add some plugin dependencies. (Open the plugin.xml and switch to the dependencies tab)
org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.papyrus.infra.gmfdiag.common,
org.eclipse.papyrus.infra.core,
org.eclipse.papyrus.uml.tools,
org.eclipse.papyrus.uml.diagram.wizards,
org.eclipse.papyrus.uml.diagram.common,
org.eclipse.ui.ide,
org.eclipse.papyrus.infra.gmfdiag.commands,
org.eclipse.papyrus.uml.diagram.clazz,
org.eclipse.papyrus.uml.diagram.activity,
org.eclipse.papyrus.editor,
org.eclipse.jdt.core,
org.eclipse.core.expressions,
org.eclipse.ui.workbench,
org.junit,
org.eclipse.gef,
org.eclipse.gmf.runtime.diagram.ui
(and again I think you won't need all of these)
András
Re: Creating models (uml,notation and di) programatically tutorial [message #1694286 is a reply to message #1496085] |
Mon, 04 May 2015 04:02  |
During the last few Months I've found a better way to achieve model creation in Papyrus:
Watching the org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard class I've found out that there is a Command for Model Creation:
It's called: NewPapyrusModelCommand
The wizard calls this command, initializes the registry and creates a model considering the selected diagrams. (In our case it's an empty model)
The following code should do the work:
//Starting the registry
try {
// have to create the model set and populate it with the DI model
// before initializing other services that actually need the DI
// model, such as the SashModel Manager service
registry.startServicesByClassKeys(ModelSet.class);
// Ignore this exception: some services may not have been loaded,
// which is probably normal at this point
ModelSet modelSet = registry.getService(ModelSet.class);
//The modelname is the name of your model
URI diPResURI = URI.createPlatformResourceURI(modelname+".di", true);
RecordingCommand command = new NewPapyrusModelCommand(modelSet, diPResURI);
modelSet.getTransactionalEditingDomain().getCommandStack().execute(command);
//Initializing the registry
try {
registry.getService(IPageManager.class);
//Creating specific model
Map<String, DiagramCategoryDescriptor> categories = DiagramCategoryRegistry.getInstance().getDiagramCategoryMap();
String key = "sysml" //the three possibilities are: uml, sysml and profile
IModelCreationCommand creationCommand = categories.get("uml").getCommand();
Current Time: Sun Jul 20 15:25:51 EDT 2025
Powered by FUDForum. Page generated in 0.05379 seconds
