Home » Eclipse Projects » e(fx)clipse » e(fx)clipse CSS validation questions
e(fx)clipse CSS validation questions [message #1404278] Wed, 30 July 2014 16:54 Go to next message
Hey Tom, first of all, thanks for all of your hard work!
Couple of questions, I recently installed e(fx)clipse from the nightly build update site (http://download.eclipse.org/efxclipse/updates-nightly/site/).
I wanted to start playing around with CSS so I created a new Java FX project in Eclipse and copy and pasted in the Modena source files from the jdk_1.8.0_05 javafx demos and samples. My thought was to try and customize modena.css and then view the changes using the Modena sample application since it conveniently displays most (all?) of the controls.
So I extracted modena.css from the jfxrt.jar file that comes with the JDK and copied it over into my src/main/resources folder in my Eclipse project.
My first issue was that it seemed like the CSS validator does not recognize the vast majority of javafx CSS attributes (e.g. -fx-base). I support for that coming in a subsequent release?
Regardless, I started customizing some of the CSS attributes. Now as you know the modena.css file is pretty large (>3000 lines). It was not possible for me to quickly re-run the application because Eclipse would take lots of time on the "parsing and validating custom_modena.css" task (~ 1-2 minutes). I'm on a pretty fast Linux machine so that was surprising. Any ideas?
Thanks again for all your awesome work!
Joe
Re: e(fx)clipse CSS validation questions [message #1404308 is a reply to message #1404278] Thu, 31 July 2014 03:27 Go to previous messageGo to next message
What you see is a regression caused by the fact that e(fx)clipse css
toolsuite got a lot cleverer in 1.0.0 by analyzing the classpath for
cssext-Files so that libraries like (controlsfx, our own pane libs)
added would contribute to the look up process.
I've filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=440836 and we
just pushed the initial change which fixes 90% of the performance
problem a 2nd improvement will follow Monday which is our internal
e(fx)clipse day.
A new build has been published so if you check for updates on
http://download.eclipse.org/efxclipse/updates-nightly/site/ you should
get a performance boost, validation still takes a few seconds but is no
more than 5 seconds in modena.css for me now.
The problems with "-fx-base" and friends who are variables (they are NOT
attributes on Nodes!) is something that is on our list of future
improvements but I don't think we can get something in for 1.0
Tom
> build update site
> project.
> Joe
Re: e(fx)clipse CSS validation questions [message #1404341 is a reply to message #1404308] Thu, 31 July 2014 06:48 Go to previous messageGo to next message
I went through the modena.css and added some missing properties (and
filed some bugs against JavaFX because they use invalid properties -
this happens if you use an editor who does not understand the valid
properties for a selector)!
If you come across more of them please add file a bug against e(fx)clipse
Tom
On 31.07.14 09:27, Tom Schindl wrote:
> e(fx)clipse day.
> Tom
>> build update site
>> project.
>> Joe
Re: e(fx)clipse CSS validation questions [message #1404354 is a reply to message #1404341] Thu, 31 July 2014 09:05 Go to previous message
Awesome news! Thanks again for you and your team's hard work!
Previous Topic:Using Jemmy for e4 javafx application
Next Topic:Console Error Output when using FXCanvas
Current Time: Sat Jul 19 17:40:59 EDT 2025
Powered by FUDForum. Page generated in 0.18433 seconds
