Home » Eclipse Projects » Eclipse 4 » RCP Startup Linux Ubuntu 14.04 Blank Screen
RCP Startup Linux Ubuntu 14.04 Blank Screen [message #1402919] Fri, 18 July 2014 07:16 Go to next message
i have a RCP application which is based on a product configuration. The product
uses 3.8 plugins and the compatibility layer with Eclipse 4.4, JRE 1.8.05.
If i start the product from within Eclipse everything works fine with Windows. However
if i'm trying to start the product under Ubuntu the Splash screen appears but then the application doesn't startup correctly and a blank inactive screen is indicated in the Linux taskbar.
Is this a known error. Any information would be appreciated
Re: RCP Startup Linux Ubuntu 14.04 Blank Screen [message #1403248 is a reply to message #1402919] Tue, 22 July 2014 11:42 Go to previous messageGo to next message
Is the app in the background (i.e., not the active window)? Does making it the active window start the app?
Otherwise follow some of the suggestions in the "How to Report a Deadlock" page and report back.
Brian.
Re: RCP Startup Linux Ubuntu 14.04 Blank Screen [message #1403491 is a reply to message #1403248] Thu, 24 July 2014 03:47 Go to previous messageGo to next message
OK. I have to investigate this further if a deadlock occurs. I thought this would be a known bug.
Brian, thanks for the reply.
Re: RCP Startup Linux Ubuntu 14.04 Blank Screen [message #1404029 is a reply to message #1403491] Tue, 29 July 2014 04:57 Go to previous message
The bug i described is a deadlock situation which has nothing to do with the platform in general. It is a resolvable problem in my application.
Again thanks for the info Brian.
Previous Topic:Incorporation of Gef plugin to e4 app
Next Topic:CSS Problems RCP
Current Time: Sun Jul 20 10:00:17 EDT 2025
Powered by FUDForum. Page generated in 0.05691 seconds
