Oomph doesn't show any Products [message #1403896] |
Mon, 28 July 2014 09:56  |
I'm feeling like i'm spamming this forum, sorry for that.
I was testing a .setup file in windows. This file(almost) works fine under Mac OS X.
What does not work in Mac OS X is the auto discovery of the setup file. I tried putting it next to the setup-eclipse.app as well as into setup-eclipse.app/Contents/MacOs
But i can put it into the list by drag&drop on the Eclipse.org container of the projects selection list.
Now, in windows the auto discovery doesn't work either, but dragging&dropping doesn't work either. I get the cursor that indicates that the setup file can't be dropped.
Next i tried editing my user setup file at HOME/.eclipse/org.eclipse.oomph.setup/setups/user.setup according to the discussion at https://www.eclipse.org/forums/index.php/t/780854/
It didn't work. THe file didn't show up. When i checked the file again, my changes were gone. Restarting the Setup again, i discovered that the Product selection list was completely empty! Clicking refresh didn't work, the popup was only there for half a second.
To fix my oomph setup, i tried to delete the HOME/.eclipse/ and HOME/.p2/ folders, but still the list was completely empty.
Half an hour later, clicking refresh suddenly works. Now my Oomph works again, but i still face the original problem: I can't get my setup into the Projects selection list.
How do i get my setup to appear in the projects selection list in Windows? Preferably without requiring drag&drop or editing of files.
Re: Oomph doesn't show any Products [message #1403961 is a reply to message #1403948] |
Mon, 28 July 2014 13:54   |
Johannes,
Comments below.
On 28/07/2014 7:01 PM, Johannes Dorn wrote:
> I've managed to get the setup into the project selection list by
> manually putting it into the org.eclipse.project.setup file, thank you
> Abel.
> This shows that the .setup file itself is valid.
> Unfortunately, this does not solve the main problem. The setup file
> should be picked up automatically when placed next to the
> setup-eclipse.exe, or at least by drag&drop.
No, it must be in a catalog, but yes, drag and drop should put it there.
> FYI, under OS X i can drag&drop the setup into any container, e.g.
> github.com.
You're sure you're on the second page of the wizard? Of course you
can't drag and drop once it's already in there...
Re: Oomph doesn't show any Products [message #1403998 is a reply to message #1403972] |
Tue, 29 July 2014 00:59  |
Johannes,
It works for me on Windows, so I'm not sure the problem. In any case,
something more discoverable is needed, i.e., either a context menu
action or a button (and of course it should be possible to remove a
project as well as add it), so please open an enhancement request.
On 28/07/2014 10:01 PM, Johannes Dorn wrote:
> Yes, i am sure i am on the second page.
> And the setup isn't already there.
> As Andreas has pointed out in
> https://www.eclipse.org/forums/index.php/i/ this only affects the
> standalone installer under windows.
> When Using the Import Project button from within Eclipse, the dialog
> accepts the same file via drag&drop.
FUDForum. Page generated in 0.04065 seconds
