Home » Language IDEs » C / C++ IDE (CDT) » Eclipse Luna, MinGW-w64 -- C++11 <random>(Eclipse doesn't recognize C++11 random)
Eclipse Luna, MinGW-w64 -- C++11 <random> [message #1403771] Sat, 26 July 2014 11:21 Go to next message
Under newly-released Luna and new CDT for Windows x64 with MinGW-W64 (tried two different compilers) 4.8.2, Eclipse does not seem to index the <random> header. Using the code below results in red squigglies with messages:
1) "Type 'std::random_device' could not be resolved"
2) "Symbol 'uniform_int_distribution' could not be resolved"
However, the program DOES build and run in Eclipse.
C++11 support is enabled via Dialect option. I also tried the old way with both -std=c++0x and -std=c++11.
The program compiles and outputs correctly when compiled on the command line. It also works using QTCreator pointing to the same compiler. No errors are reported in either case.
#include <iostream>
#include <random>
int main()
    std::random_device rng;
    std::uniform_int_distribution<> uid(1, 10);
    for(std::size_t i = 0; i < 10; i++)
        std::cout << uid(rng) << " ";
    std::cout << std::endl;
    return 0;
Am I doing something wrong?
Re: Eclipse Luna, MinGW-w64 -- C++11 <random> [message #1403806 is a reply to message #1403771] Sun, 27 July 2014 16:53 Go to previous messageGo to next message
Hello Kamil,
disable Codan (Code Analysis) to remove the warnings:
http://wiki.eclipse.org/CDT/User/NewIn70#Code_Analysis
You also could check bugzilla if this problem is already known:
https://bugs.eclipse.org/bugs/buglist.cgi?query_format=advanced;component=cdt-codan;bug_status=UNCONFIRMED;bug_status=NEW;bug_status=ASSIGNED;bug_status=REOPENED;product=CDT;classification=Tools
regards,
Klaus
Re: Eclipse Luna, MinGW-w64 -- C++11 <random> [message #1403886 is a reply to message #1403806] Mon, 28 July 2014 09:04 Go to previous messageGo to next message
Hi Klaus,
Thank you for the reply.
Disabling code analysis isn't a great solution, so back to Kepler for now.
It doesn't look like there is an open bug for this so I will file one and post the link here.
Edit: https://bugs.eclipse.org/bugs/show_bug.cgi?id=440558
[Updated on: Mon, 28 July 2014 10:23] by Moderator
Re: Eclipse Luna, MinGW-w64 -- C++11 <random> [message #1403918 is a reply to message #1403886] Mon, 28 July 2014 11:07 Go to previous messageGo to next message
Hi Kamil,
i get the same errors with Kepler. I'm wondering, why this does not happen with Kepler in your workspace. Maybe you already have disabled Codan in Kepler?
Thanks for the bugzilla link.
regards,
Klaus
Re: Eclipse Luna, MinGW-w64 -- C++11 <random> [message #1403932 is a reply to message #1403918] Mon, 28 July 2014 12:01 Go to previous messageGo to next message
Klaus,
That is strange. I have brand-new, completely untouched Kepler and Luna in exactly the same environment. Code analysis seems to be enabled in both versions. Kepler doesn't give me an error; Luna does.
The only difference between the two is the path, but since they live side-by-side it shouldn't make a difference.
D: --> dev --> eclipse_kepler --> eclipse --> eclipse.exe
D: --> dev --> eclipse_luna --> eclipse --> eclipse.exe
Re: Eclipse Luna, MinGW-w64 -- C++11 <random> [message #1403952 is a reply to message #1403932] Mon, 28 July 2014 13:11 Go to previous messageGo to next message
I used (Windows 7, btw.)
Luna: Eclipse Platform Version 4.4.0 and CDT Version 8.4.0
Kepler: Eclipse Platform Version 4.3.2 and CDT Version 8.3.0
and get the same error with both versions.
Hm, could you compare the Codan settings in both projects?
There are two locations for the settings.
General:
Windows -> Preferences -> C/C++ -> Code Analysis
Project-specific:
Project -> Properties -> C/C++ General -> Code Analysis
regards,
Klaus
Re: Eclipse Luna, MinGW-w64 -- C++11 <random> [message #1404517 is a reply to message #1403952] Sat, 02 August 2014 14:44 Go to previous message
Hi Klaus,
Apologies for the delay -- away for work for a few days with no access to a Windows PC.
Codan settings were identical. However, I know why I was getting different results. Kepler wasn't "completely untouched" as I had said -- in fact, I had added the -std=c++11 flag to the "Command to get compiler specs" (workspace-wide) the previous night and then forgotten about it. All other settings are the same.
Please also see my latest post on the bugzilla. This seems to solve the problem in Luna and in Kepler -- however, I find it strange that it is necessary with the new "Dialect" option. Nonetheless, there it is.
Thanks for your help!
[Updated on: Sat, 02 August 2014 14:46] by Moderator
Previous Topic:Index and AST connection
Next Topic:C++11 CMake based project no support in indexer
Current Time: Sun Jul 20 04:24:11 EDT 2025
Powered by FUDForum. Page generated in 0.07807 seconds
