Home » Modeling » EMF » [DynamicEMF] How to set an unchangeable using DynamicEMF
[DynamicEMF] How to set an unchangeable using DynamicEMF [message #1403701] Fri, 25 July 2014 08:54 Go to next message
Hi guys,
I have an interface in my model defined like this:
abstract class Identifiable { interface }
    attribute identifier : String { id readonly };
When I generate the code, I need to change the generated code in the following manner to set the "identifier" attribute:
     * The default value of the '{@link #getIdentifier() <em>Identifier</em>}' attribute. <!-- begin-user-doc --> <!-- end-user-doc -->
     * @see #getIdentifier()
     * @generated
     * @ordered
    protected static final String       IDENTIFIER_EDEFAULT = null;
     * The cached value of the '{@link #getIdentifier() <em>Identifier</em>}' attribute. <!-- begin-user-doc --> <!-- end-user-doc -->
     * @generated
     * @ordered
    protected String                    identifier          = UUID.randomUUID().tostring();
This works fine for instances created through the package factory.
However, sometimes I need to instantiate these objects with dynamic EMF:
    // Here, the provided eClass has "Identifiable" as a super type
    EObject instance = new DynamicEObjectImpl(eClass);
    try {
        EcoreUtil.setID(instance, UUID.randomUUID.toString)
    } catch (IllegalArgumentException e) {
        // Oops
And I can't set the identifier because the feature is not changeable. Is there a way to set "unchangeable" field there ?
Note that the provided EClass is created dynamically as well and inherits "Indentifiable":
        val newClass = eb.eClass.name(userClass.name).build
        newClass.EStructuralFeatures += userClass.fields.map [
        // new eClass needs to have an identifier as well
        newClass.ESuperTypes += IDENTIFIABLE
BQ.
Re: [DynamicEMF] How to set an unchangeable using DynamicEMF [message #1403707 is a reply to message #1403701] Fri, 25 July 2014 09:09 Go to previous messageGo to next message
Why not just make it read/write in your model? Otherwise you won't ever
be able to save/load instances and conserve the identifier. I don't
think you're supposed to change a metaattribute at runtime
(EPackage.freeze())?
Felix
Re: [DynamicEMF] How to set an unchangeable using DynamicEMF [message #1403710 is a reply to message #1403707] Fri, 25 July 2014 09:23 Go to previous messageGo to next message
Hi Felix,
That's what I'm currently doing, but I'm using the model to generate various things and I'm currently handling the "identifier" as a special case. It's not really handy and I was wondering if there was another way.
BQ.
Re: [DynamicEMF] How to set an unchangeable using DynamicEMF [message #1403715 is a reply to message #1403701] Fri, 25 July 2014 10:03 Go to previous message
Bertrand,
Comments below.
On 25/07/2014 2:54 PM, Bertrand Quenin wrote:
> Hi guys,
> end-user-doc -->
> * * @see #getIdentifier()
> * @generated
> * @ordered
> end-user-doc -->
> * @generated
> * @ordered
Is this feature also transient? When reading something in, you don't
generally want to do this.
> try {
> // Oops
Probably better to use
org.eclipse.emf.ecore.impl.MinimalEObjectImpl.Container.Dynamic, but
that's just a footprint consideration.
If it's a dynamic Ecore model, you can make it changeable in that
model. Presumably it's not the generated model, otherwise you'd not be
trying to make a dynamic version of it.
Oh, so the unchangeable generated class already has the problem.
You really need to rethink how these IDs are managed. If you're going
to save instances, presumably you want the ID preserved when you read it
back in. That obviously don't work at all. So what's the purpose of
this "auto generating" of an ID? Is that something you need
programmatically or something you need to make the user's life easier?
Perhaps better would be for the resource to manage the assignment of
IDs, much as XMLResourceImpl manages extrinsic IDs, but perhaps melding
the two approaches and have the resource assign an ID to any object that
doesn't already have an ID that's set....
> Regards,
> BQ.
Previous Topic:[XCORE] Loosing Memory/Memory Exhaustion
Next Topic:[CDO] Unable to launch our product due to CDO issues
Current Time: Sun Jul 20 11:06:01 EDT 2025
Powered by FUDForum. Page generated in 0.04253 seconds
