Home » Archived » Jubula » Create an action for Application
Create an action for Application [message #1403182] Tue, 22 July 2014 04:36 Go to next message
I try to create a new action for Application.
But i don't know what is the toolkitComponent type for Application (to complete ComponentConfiguration.xml)
In the example (JSlider), the toolkitComponent type is javax.swing.JSlider.
Thanks to your help.
Déborah
Re: Create an action for Application [message #1403189 is a reply to message #1403182] Tue, 22 July 2014 05:36 Go to previous messageGo to next message
I don't know what do it put in node <extends>.
Someone can help me, please?
Re: Create an action for Application [message #1403667 is a reply to message #1403189] Fri, 25 July 2014 03:39 Go to previous messageGo to next message
<?xml version="1.0" encoding="ISO-8859-1"?>
<compSystem xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ComponentConfiguration.xsd">
	<configVersion>
		<majorVersion>1</majorVersion>
		<minorVersion>36</minorVersion>
	</configVersion>
	<!-- Concrete components -->
	<toolkitComponent type="..." visible="true">
		<realizes>...</realizes>
		<!-- <extends>...</extends> -->
		<testerClass>...</testerClass>
		<componentClass name="..." />
	</toolkitComponent>
</compSystem>
I tried several ways to fill nodes, but none works.
Nothing happen in jubula.
Re: Create an action for Application [message #1403721 is a reply to message #1403667] Fri, 25 July 2014 10:36 Go to previous message
I try this way, but it doesn't work...
feature.xml:
<feature
      id="com.***.jubula.extension.feature"
      label="Feature"
      version="1.0.0.qualifier"
      provider-name="***">
   <description url="http://www.example.com/description">
      [Enter Feature Description here.]
   </description>
   <copyright url="http://www.example.com/copyright">
      [Enter Copyright Description here.]
   </copyright>
   <license url="http://www.example.com/license">
      [Enter License Description here.]
   </license>
</feature>
plugin.xml:
<?eclipse version="3.4"?>
<plugin>
   <extension
         point="org.eclipse.jubula.toolkit.common.toolkitsupport">
      <toolkit
            IToolkitProvider="com.***.jubula.extension.toolkit.provider.MyToolkitProvider"
            includes="null"
            isUserToolkit="true"
            level="concrete"
            name="Jubula Drag And Drop Application"
            order="1"
            toolkitID="com.***.jubula.extension.toolkit">
      </toolkit>
   </extension>
</plugin>
toolkitProvider:
package com.***.jubula.extension.toolkit.provider;
import java.net.URL;
import java.util.Map;
import java.util.ResourceBundle;
import org.eclipse.jubula.toolkit.common.IToolKitProvider;
import org.eclipse.jubula.toolkit.common.exception.ToolkitPluginException;
import org.eclipse.jubula.toolkit.common.utils.ToolkitUtils;
import org.eclipse.swt.widgets.Composite;
import com.***.jubula.extension.toolkit.Activator;
public class MyToolkitProvider implements IToolKitProvider {
    /** the bundle location */
    public static final String BUNDLE = "com.***.jubula.extension.toolkit.i18n.i18n";
    public URL getComponentConfigurationFileURL() {
        return ToolkitUtils.getURL(Activator.getDefault(), "resources/xml/ComponentConfiguration.xml");
    public ResourceBundle getI18nResourceBundle() {
        return ResourceBundle.getBundle(BUNDLE);
    public Composite getAutConfigDialog(Composite parent, int style, Map<String, String> autConfig, String autName) throws ToolkitPluginException {
        return null;
ComponentConfiguration.xml: (I don't know what put for the type of concreteComponent)
	<configVersion>
		<majorVersion>0</majorVersion>
		<minorVersion>5</minorVersion>
	</configVersion>
	<concreteComponent type="GraphicApplication">
    	<extends>guidancer.concrete.GraphicApplication</extends>
    	<testerClass>org.eclipse.jubula.rc.swing.tester.AppTester</testerClass>
		<action name="CompSystem.Drag">
			<method>rcDrag</method>
			<param name="CompSystem.MouseButton">
				<type>java.lang.Integer</type>
				<defaultValue>1</defaultValue>
				<valueSet>
					<element name="CompSystem.MouseButtonLeft" value="1"/>
					<element name="CompSystem.MouseButtonMiddle" value="2"/>
					<element name="CompSystem.MouseButtonRight" value="3"/>
				</valueSet>
			</param>
			<param name="CompSystem.ModifierSpecification">
				<type>java.lang.String</type>
				<defaultValue>none</defaultValue>
				<valueSet combinable="true">
					<element name="CompSystem.None" value="none"/>
					<element name="CompSystem.Shift" value="shift"/>
					<element name="CompSystem.Ctrl" value="control"/>
					<element name="CompSystem.Alt" value="alt"/>
					<element name="CompSystem.Meta" value="meta"/>
					<element name="CompSystem.Cmd" value="cmd"/>
					<element name="CompSystem.Mod" value="mod"/>
				</valueSet>
			</param>
			<param name="CompSystem.XPos">
				<defaultValue>50</defaultValue>
			</param>
			<param name="CompSystem.XUnits">
				<defaultValue>percent</defaultValue>
				<valueSet>
					<element name="CompSystem.Percent" value="percent"/>
					<element name="CompSystem.Pixel" value="pixel"/>
				</valueSet>
			</param>
			<param name="CompSystem.YPos">
			</param>
			<param name="CompSystem.YUnits">
				<valueSet>
				</valueSet>
			</param>
		</action>
		<action name="CompSystem.Drop">
			<method>rcDrop</method>
			</param>
				<valueSet>
				</valueSet>
			</param>
			</param>
				<valueSet>
				</valueSet>
			</param>
			<param name="CompSystem.DelayBeforeDrop">
				<defaultValue>100</defaultValue>
			</param>
		</action>
	</concreteComponent>
</compSystem>
i18n:
GraphicApplication=Application
CompSystem.Alt=Alt
CompSystem.Cmd=Cmd
CompSystem.Ctrl=Ctrl
CompSystem.DelayBeforeDrop=Delay Before Drop
CompSystem.Drag=Drag
CompSystem.Drop=Drop
CompSystem.Meta=Meta
CompSystem.Mod=Mod
CompSystem.MouseButton=Mouse Button
CompSystem.MouseButtonLeft=Mouse Button Left
CompSystem.MouseButtonMiddle=Mouse Button Middle
CompSystem.MouseButtonRight=Mouse Button Right
CompSystem.ModifierSpecification=Modifier Specification
CompSystem.None=None
CompSystem.Percent=Percent
CompSystem.Pixel=Pixel
CompSystem.Shift=Shift
CompSystem.XPos=x-position
CompSystem.XUnits=x-units
CompSystem.YPos=y-position
CompSystem.YUnits=y-units
componentConfiguration.xsd:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified">
<xs:include schemaLocation="../../../ToolkitSupportPlugin/resources/xml/ToolkitComponentConfiguration.xsd"/>
</xs:schema>
AppTester.java:
package org.eclipse.jubula.rc.common.tester;
import java.awt.Rectangle;
import org.eclipse.jubula.rc.common.driver.IRobot;
public class AppTester extends AbstractApplicationTester{
	public void rcDrag(int mouseButton, String modifierKeys, int XPos, String XUnits, int YPos, String YUnits){
	public void rcDrop(int XPos, String XUnits, int YPos, String YUnits, int delayBeforeDrop){
	public String[] getTextArrayFromComponent() {
		// TODO Auto-generated method stub
		return null;
	public Rectangle getActiveWindowBounds() {
		return null;
	protected IRobot getRobot() {
		return null;
	public void rcKeyStroke(String modifierSpec, String keySpec) {
	protected Object getFocusOwner() {
		return null;
	protected int getEventCode(int key) {
		return 0;
	protected Object getActiveWindow() {
		return null;
site.xml:
<site>
   <feature url="features/com.***.jubula.extension.feature_1.0.0.201407251534.jar" id="com.***.jubula.extension.feature" version="1.0.0.201407251534">
      <category name="com.***.jubula.extension.feature"/>
   </feature>
   <category-def name="com.***.jubula.extension.feature" label="Jubula Drag And Drop Application"/>
</site>
I build in site.xml and i install new software in Eclipse.
[Updated on: Fri, 25 July 2014 10:46] by Moderator
Previous Topic:Show AUT's variable on screen
Next Topic:Out of memory while writing test result report
Current Time: Sat Jul 19 21:20:04 EDT 2025
Powered by FUDForum. Page generated in 0.03705 seconds
