Home » Eclipse Projects » Eclipse 4 » CommandContributionItem parameterization not working in Main Menu(bug or feature?)
CommandContributionItem parameterization not working in Main Menu [message #1402650] Thu, 17 July 2014 05:38 Go to next message
I'm working in E4 compatibility mode, in a application that is using CommandContributionItem for dinamically add items to the Main Menu.
This is being added at the ApplicationActionBarAdvisor.fillMenuBar (in case it affects the bootup flow)
The code would be something as:
CommandContributionItemParameter aEnParam = new CommandContributionItemParameter(theWindow, "Language.en.Label", "com.compxc.workbench.presentation.command.changeLanguageCommand", IAction.AS_RADIO_BUTTON);
aEnParam.label = ResourceManager.getText("Language.en.Label");
HashMap<String, String> aEnParamMap = new HashMap<String, String>();
aEnParamMap.put("org.eclipse.ui.commands.radioStateParameter", "EN");
aEnParam.parameters = aEnParamMap;
englishAction = new CommandContributionItem(aEnParam);
theMenuBar.add(englishAction);
Although I can see it being correctly parameterized with my value, when I get to the execution in the Handler, the Event doesn't bring any parameter.
A similar example in a context menu, with the same code creating the Contribution works just fine, and the Handler receives the parameter.
Any idea how to fix this, or how to generate a Command based Contribution with correct parameterization?
Re: CommandContributionItem parameterization not working in Main Menu [message #1402690 is a reply to message #1402650] Thu, 17 July 2014 06:54 Go to previous message
After doing a quick test on E3 and E4 this really seems like a bug, since it works fine with E3 target but not with E4 (luna).
Follows a simple test based in mail application
Previous Topic:To migrate or not to migrate (Indigo to Luna)
Next Topic:Luna Editor bugs
Current Time: Sun Jul 20 03:45:16 EDT 2025
Powered by FUDForum. Page generated in 0.03451 seconds
