Home » Eclipse Projects » GEF » DirectEditManager
DirectEditManager [message #139712] |
Wed, 23 June 2004 13:22  |
The DirectEditManager installs an ancestor listener on the editpart's figure
and relocates the cell editor upon handling the event. So basically, if the
label is nested within say 5 containers and one more character is inserted,
that causes the label to revalidate which means all the containers will be
resized appropriately. The problem now is that the relocate will be called 5
times, once for each container (in fact the figure will not have resized
itself appropriately until at the end when its bounds is set). That causes
the text widget to flicker.
Is there a real reason for the ancestor listening? isn't figure bounds
listening enough? Thanks.
Maged Elaasar
Re: DirectEditManager [message #139767 is a reply to message #139745] |
Wed, 23 June 2004 14:37   |
"Maged Elaasar" <melaasar@ca.ibm.com> wrote in message
news:cbcguq$5t7$1@eclipse.org...
> 1- The ancestor listening also happens if the size only has changed (so
you
> could get 5 events) In addition, depending on the layouts used, some
I know you get 5 events. But is setBounds() called on the CellEditor with 5
unique values? Just put an optimization in your Locator where you don't
call setBounds() if the location is not changing.
> parents might really move when the label's size changes.
> 2- Can you elaborate on the case where parents use local coordinates? I
> thought the bounds of the text widget should be based on those of the
label
> regardless of parents. So if the label does not move (for some reason or
> another) the widget also should not.
If any parent has useLocalCoordinates() returning true, or Viewport with
virtual scrolling.
> "Randy Hudson" <none@us.ibm.com> wrote in message
> news:cbcfma$344$1@eclipse.org...
> > news:cbce8d$vq7$1@eclipse.org...
> > > Hello,
> > figure
if
> > the
> > inserted,
will
> be
> called
> > 5
> > Do all 5 containers change their location as well? If the bounds are
not
> > changing there should be no effect. You should only see two changes,
when
> > the top-left corner moves, and the size.
resized
> causes
> > The parent may have local coordinates and therefore doesn't translate
its
> > children.
> > > Maged Elaasar
Re: DirectEditManager [message #139990 is a reply to message #139767] |
Fri, 25 June 2004 07:39   |
The label I am using supports wrapping. So the locator has code like that:
Text text = (Text) celleditor.getControl();
Rectangle rect = getLabel().getTextBounds().getCopy();
getLabel().translateToAbsolute(rect);
if (getLabel().isTextWrapped())
rect.setSize(new Dimension(text.computeSize(rect.width, rect.height)));
else
rect.setSize(new Dimension(text.computeSize(SWT.DEFAULT, SWT.DEFAULT)));
if (!rect.equals(new Rectangle(text.getBounds())))
text.setBounds(rect.x, rect.y, rect.width, rect.height);
The problem with ancestor listening here is that during all the events I
will be getting except the last one, the label figure will be still
"invalid" (from the addition of the character), which means the
getTextBounds will be calculated using the old size (but with the new text)
which gives incorrect bounds. Eventually when the label is validated, the
correct size is set and the bounds returned is correct. However, I see the
flickering.
Do you have a suggestion to fix that? One way I thought of is to check if
the label figure is valid before relocating. However, I am not sure if this
is as good as removing the ancestor listening and replacing it with a figure
listener (will I loose something?)
I appreciate any feedback
news:cbcika$97p$1@eclipse.org...
> you
5
> label
> virtual scrolling.
> > > > Hello,
editpart's
> > > figure
> if
> > > the
> > > inserted,
> will
> > be
> > called
> > > 5
> not
> when
> resized
> > causes
bounds
> its
> > > children.
> > > > Maged Elaasar
Re: DirectEditManager [message #140001 is a reply to message #139990] |
Fri, 25 June 2004 08:39   |
I just realized that checking for validation won't work since a figure is
validated after it is laid out. Anyways, I think the scenario I am talking
about could also be demostrated as follows:
You have a shape that has a name label which is centered in the shape.
Adding a new character causes the label to revalidate which will also clear
its cached local variables including textLocation. As the cell editor
locator is listening to the label's ancestors being laid out, it calls
getTextBounds() which will cause the textLocation to be recalculated with
the new text but with the old size leading to incorrect bounds. Only when
the label itself is laid out with the correct bounds, that the getTextBounds
returns correct result.
I tried your suggestion of only setting the bounds of the editor with unique
values which reduced the flickering, however, I still get two unique values
per character typed, one when the label has new text but old size, and
another when it has both the new text and size. This would cause flicking,
especially if the two sizes are way off (it shows more in my case due to the
text wrapping).
I appreciate any more suggestions.
news:cbh2tk$ub3$1@eclipse.org...
rect.height)));
> else
SWT.DEFAULT)));
text)
> flickering.
this
figure
(so
> > you
with
> 5
I
> > label
or
> > virtual scrolling.
> > > > > Hello,
> editpart's
> > > > figure
basically,
> > if
> > > > the
> > > > inserted,
> > will
> > > be
be
> > > called
> > > > 5
are
> > not
changes,
> > when
> > resized
That
> > > causes
> bounds
translate
> > its
> > > > children.
> > > > > Maged Elaasar
Re: DirectEditManager [message #140054 is a reply to message #140001] |
Fri, 25 June 2004 10:11   |
In the past, we used to add a Verify Listener to the Text control in the
Logic Example. This would enlarge the Text widget prior to the new text
being inserted, which prevents the text from scrolling horizontally when it
doesn't fit.
verifyListener = new VerifyListener() {
public void verifyText(VerifyEvent event) {
Text text = (Text)getCellEditor().getControl();
String oldText = text.getText();
String leftText = oldText.substring(0, event.start);
String rightText = oldText.substring(event.end, oldText .length());
GC gc = new GC(text);
String s = leftText + event.text + rightText;
Point size = gc.textExtent(leftText + event.text + rightText);
gc.dispose();
if (size.x != 0)
size = text.computeSize(size.x, SWT.DEFAULT);
getCellEditor().getControl().setSize(size.x, size.y);
The control may still be sized multiple times, but it will not shift the
text around which I think is causing the flickering.
news:cbh6d4$5u1$1@eclipse.org...
clear
getTextBounds
unique
values
the
> text wrapping).
that:
> rect.height)));
> > else
> SWT.DEFAULT)));
> text)
the
the
> > flickering.
if
> this
> figure
> (so
> > > you
some
> with
> > 5
don't
coordinates?
> I
the
> > > label
reason
> or
with
> > > virtual scrolling.
> > > > > > Hello,
> > editpart's
> > > > > figure
> basically,
> > > if
> > > > > the
is
> > > > > inserted,
containers
> > > will
> > > > be
> be
> > > > called
> > > > > 5
> are
> > > not
> changes,
> > > when
> > > resized
> That
> > > > causes
> > bounds
> translate
> > > its
> > > > > children.
> > > > > > Maged Elaasar
Re: DirectEditManager [message #140122 is a reply to message #140054] |
Fri, 25 June 2004 11:17   |
In the example I gave, it is the location "not" the size that will be
incorrect. so yes the verify listener would make sure there is enough size,
but the locator that does setBounds will initially set incorrect location
then eventually it will set it correctly when the label is laid out. The
flickering in this case is caused by the location movement.
news:cbhbpj$i0v$1@eclipse.org...
it
> doesn't fit.
> gc.dispose();
> if (size.x != 0)
is
talking
> clear
with
when
> getTextBounds
> unique
> values
flicking,
> the
> > text wrapping).
> that:
> > rect.height)));
> > > else
> > SWT.DEFAULT)));
I
> > text)
> the
> the
> > > flickering.
> if
> > this
> > figure
changed
> > (so
> > > > you
> some
CellEditor
> > with
> > > 5
> don't
> coordinates?
> > I
> the
> > > > label
> reason
> > or
> with
> > > > virtual scrolling.
> > > > > > > Hello,
> > > editpart's
> > > > > > figure
> > basically,
> > > > if
> > > > > > the
> is
> > > > > > inserted,
> containers
> > > > will
> > > > > be
will
> > be
> > > > > called
> > > > > > 5
bounds
> > are
> > > > not
> > changes,
> > > > when
have
> > > > resized
> > That
> > > > > causes
figure
> > > bounds
> > translate
> > > > its
> > > > > > children.
> > > > > > > Maged Elaasar
Re: DirectEditManager [message #140284 is a reply to message #140252] |
Fri, 25 June 2004 17:15  |
I will try to reproduce using the Logic example code...
However the scenario is like this:
1- a character more is inserted in the text cell editor which reflects in
the Label right away.
2- revalidate of the Label is called, which invalidates the Label and all
its ancestors. Invalidate will clear all the cached variables including
textLocation.
3- update manger now does an update and calls validate on all the ancestors
of the label from top down.
4- With every ancestor being laid out and its bounds changing, an event is
fired and the cell editor tries to relocate, so the first event will cause
the locator to call Label.getTextBounds() which will find the cached vars
cleared and hence will try to rebuild them.
5- The situation now is that the Label has the new text (with the added
char) but its "size" is still not updated. Since the calculation of
textLocation uses the size, the resulting location will not be valid.
6- Finally, the label is laid out and the new size is set. This again
invalidates the Label and its cached vars. Again the locator listens to this
and this time the getTextBound tries to build the textLocation but with the
correct size this time.
7- setting the bounds of the cell editor twice with different bounds
(different locations) will cause flickering.
The reason the label location moves with an extra char is that it is
centered in its parent figure....Also, had the locator used
Label.getBounds() vs. Label.getTextBounds() it would have worked fine, since
the bounds with the first event matches that before the char is inserted, so
in essence you get only one new unique bounds to set to the text editor and
no flickering...However I cannot use that bounds since there could be an
icon.
I will try to demo this using Logic design...meanwhile tell me if that makes
sense.
news:cbhnt2$aio$1@eclipse.org...
> So the label's container moves one way, then the label moves the opposite
> way later? I can't picture how that would happen. What type of UI are we
> talking about?
> news:cbhfm5$qtt$1@eclipse.org...
> size,
location
Current Time: Sat Jul 19 07:00:37 EDT 2025
Powered by FUDForum. Page generated in 0.33438 seconds
