Eclipse & Solaris [message #140240] |
Sat, 25 February 2006 02:57  |
Originally posted by: karia.john.xxxxx.xom
I've a WebLogic 8.1 server installed on a Solaris machine. I have only
ssh/sftp access to this server. Is there any way to create a project in
eclipse with files pointing to the one in remote server (solaris) through
ssh/sftp and compile & debug programs with CLASSPATH set to remote JDK &
other jar files in solaris box. (in short, I don't want to work with local
files)
Your help is highly appreciated.
Karia
Re: Eclipse & Solaris [message #140269 is a reply to message #140240] |
Sat, 25 February 2006 12:43  |
I have Eclipse set up on Windows, and have several projects that are on a
Solaris system. I just map the network drive, and it all works fine. I can
run and debug. The project files are on the Solaris system. Running, of
course is on the local system.
I understand this is not SSH, and may not help you, but, again, it may give
you an idea. Any way to make the remote file system available should work.
-Ken
FUDForum. Page generated in 0.07636 seconds
