Home » Modeling » Epsilon » [EVL] cyclic connection
[EVL] cyclic connection [message #1400730] Mon, 14 July 2014 12:37 Go to next message
I try to write a check and I need some help. I need to proof to a cyclic connection.
https://dl.dropboxusercontent.com/u/58418042/dmn/connection.png
If I have a cyclic connection like on the picture, I have to show a error.
I looking too for an api or command overview for evl, because I know only some of the commands.
Justus
Re: [EVL] cyclic connection [message #1400877 is a reply to message #1400730] Mon, 14 July 2014 17:21 Go to previous messageGo to next message
Hi Justus,
The "closure" operation may be of use here e.g. assuming that nodes are connected via a "previous" reference, something like self.closure(n|n.previous).excludes(self) would do the trick.
Dimitris
Re: [EVL] cyclic connection [message #1401333 is a reply to message #1400877] Tue, 15 July 2014 09:03 Go to previous messageGo to next message
Hi Dimitris,
I get the error "Property 'previous' not found in object Decision". If I look in the Properties of my element, I see only the name. If I look to the link I see from and to.
Greetings,
Justus
Re: [EVL] cyclic connection [message #1401348 is a reply to message #1401333] Tue, 15 July 2014 09:21 Go to previous messageGo to next message
Hi Justus,
Could you please share your metamodel?
Dimitris
Re: [EVL] cyclic connection [message #1401351 is a reply to message #1400730] Tue, 15 July 2014 09:25 Go to previous messageGo to next message
Hi Dimitris,
the emf File?
@namespace(uri="dmn", prefix="dmn")
package dmn;
@gmf.diagram(onefile="true", diagram.extension="dmn")
class DMN {
    val Elements[*] dmn_elements;
    val Requirements[*] dmn_requirements;
abstract class Elements{
	attr String name;
abstract class IRFrom{
abstract class KRTo{
abstract class DBK{
@gmf.node(figure="figures.Decision", label="name", label.icon="false", size="200,75")
class Decision extends Elements, IRFrom, KRTo, DBK{
@gmf.node(figure="figures.BusinessKnowledgeModel", label="name" , label.icon="false", size="200,75")
class Business_knowledge_model extends Elements, KRTo, DBK{
@gmf.node(figure="figures.InputData", label="name", label.icon="false", size="200,75")
class Input_data extends Elements, IRFrom{
@gmf.node(figure="figures.KnowledgeSource", label="name", label.icon="false", size="200,75")
class Knowledge_source extends Elements, DBK{
abstract class Requirements{
@gmf.link(source="from", target="to", target.decoration="filledclosedarrow", color="0,0,0")
class Information_Requirement extends Requirements{
	ref IRFrom from;
	ref Decision to;
@gmf.link(source="from", target="to", target.decoration="arrow", style="dash", color="0,0,0")
class Knowledge_Requirement extends Requirements{
	ref Business_knowledge_model from;
	ref KRTo to;
@gmf.link(source="from", target="to", target.decoration="decoration.AuthorityRequirementDecorator", style="dash", color="0,0,0")
class Authority_Requirement extends Requirements{
	ref Elements from;
	ref Elements to;
Greetings,
Justus
[Updated on: Tue, 15 July 2014 09:25] by Moderator
Re: [EVL] cyclic connection [message #1402120 is a reply to message #1401351] Wed, 16 July 2014 10:53 Go to previous messageGo to next message
Hi Justus,
Essentially, you need to detect a cycle in your graph so I'd suggest implementing a depth-first search algorithm (see [1] for additional pointers).
Dimitris
[1] http://en.wikipedia.org/wiki/Cycle_(graph_theory)
Re: [EVL] cyclic connection [message #1402230 is a reply to message #1400730] Wed, 16 July 2014 14:20 Go to previous messageGo to next message
Hi Dimitris,
This Is what I was looking for. One more Question. How to get my Elements and Requirements in a collection?
var elements : Collection;
elements = ???
Greetings,
Justus
Re: [EVL] cyclic connection [message #1402285 is a reply to message #1402230] Wed, 16 July 2014 16:17 Go to previous messageGo to next message
Hi Justus,
The following should do the trick:
var elements : Sequence;
elements.addAll(Elements.all);
elements.addAll(Requirements.all);
Dimitris
Re: [EVL] cyclic connection [message #1402782 is a reply to message #1402285] Thu, 17 July 2014 09:44 Go to previous message
Hi Dimitris,
Thanks for your help. now it is running. EVL and EOL are realy nice. Very Happy
Greetings,
Justus
Previous Topic:[Eugenia] using properties of embedded classes in labels?
Next Topic:Use EOL operation and/or EOL files on Exeed
Current Time: Sat Jul 19 20:17:02 EDT 2025
Powered by FUDForum. Page generated in 0.06981 seconds
