Home » Eclipse Projects » e(fx)clipse » SwingNode - ClassNotFoundException
SwingNode - ClassNotFoundException [message #1401910] Wed, 16 July 2014 04:39 Go to next message
Hi all,
I'm trying to integrate a Swing component into my E4 FX application.
Therefore I have a certain Part class
import javafx.embed.swing.SwingNode;
import javafx.scene.layout.BorderPane;
import javax.annotation.PostConstruct;
import javax.swing.SwingUtilities;
import my.project.efx.swing.SwingPartJPanel;
public class SwingPart {
	@PostConstruct
	public void init(BorderPane pane) {
		SwingNode swingNode = new SwingNode();
		createSwingPart(swingNode);
		pane.setCenter(swingNode);
	private void createSwingPart(final SwingNode swingNode) {
		SwingUtilities.invokeLater(new Runnable() {
            public void run() {
            	swingNode.setContent(new SwingPartJPanel());
However, when embedding this as a Part in my E4 application and running this on JDK8 with eclipse-SDK-4.4-win32-x86_64-efx-1.0.0-SNAPSHOT I get an exception
!ENTRY org.eclipse.e4.ui.workbench 4 0 2014-07-16 10:21:55.363
!MESSAGE Unable to create class 'my.project.efx.swing.SwingPart' from bundle '36'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javafx/embed/swing/SwingNode
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:348)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:258)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
Caused by: java.lang.NoClassDefFoundError: javafx/embed/swing/SwingNode
	at java.lang.Class.getDeclaredConstructors0(Native Method)
Caused by: java.lang.ClassNotFoundException: javafx.embed.swing.SwingNode cannot be found by my.project.efx.app_1.0.0.qualifier
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	... 73 more
My plugin.xml says:
Bundle-RequiredExecutionEnvironment: JavaSE-1.8
Shouldn't javafx.embed.swing.SwingNode be found any time since it is part of the java runtime ?
Best Regards,
Danny
[Updated on: Wed, 16 July 2014 04:41] by Moderator
Re: SwingNode - ClassNotFoundException [message #1401914 is a reply to message #1401910] Wed, 16 July 2014 04:42 Go to previous messageGo to next message
Is javafx.embed.swing part of you package import?
Tom
On 16.07.14 10:39, Danny Tramnitzke wrote:
> Hi all,
> @PostConstruct
> @Override
> public void run() {
> an exception
> bundle '36'
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> ... 73 more
> Best Regards,
> Danny
Re: SwingNode - ClassNotFoundException [message #1401971 is a reply to message #1401914] Wed, 16 July 2014 06:24 Go to previous messageGo to next message
ah right, thanks !
Import-Package:
javafx.embed.swing;version="2.0.0"
Re: SwingNode - ClassNotFoundException [message #1401974 is a reply to message #1401914] Wed, 16 July 2014 06:25 Go to previous messageGo to next message
ah right, thanks!
Import-Package:
Re: SwingNode - ClassNotFoundException [message #1401975 is a reply to message #1401914] Wed, 16 July 2014 06:26 Go to previous messageGo to next message
ah right, thanks!
Import-Package:
Re: SwingNode - ClassNotFoundException [message #1401994 is a reply to message #1401914] Wed, 16 July 2014 07:00 Go to previous messageGo to next message
ok, thanks!
I added javafx.embed.swing to the Import-Package(s) in MANIFEST.MF
Now, my java.awt.Label is not displayed at the Swing-Part Sad
But it runs standanlone, though.
JFX-Part with Swing component
	@PostConstruct
            public void run() {
            	swingNode.setContent(new SwingPartPanel());
Swing component
public class SwingPartPanel extends JPanel {
	private static final long serialVersionUID = -2529807437953504842L;
	public SwingPartPanel() {
		Label swingLabel = new Label("I'm a " + Label.class.getName());
		add(swingLabel);
	public static void main(String[] args){
		javax.swing.SwingUtilities.invokeLater(new Runnable() {
			public void run() {
				JFrame jframe = new JFrame();
				jframe.add(new SwingPartPanel(), BorderLayout.CENTER);
				// Display the window.
				jframe.pack();
				jframe.setSize(800, 800);
				jframe.setVisible(true);
Re: SwingNode - ClassNotFoundException [message #1401995 is a reply to message #1401914] Wed, 16 July 2014 07:02 Go to previous messageGo to next message
ok, thanks!
	@PostConstruct
            public void run() {
Swing component
		add(swingLabel);
			public void run() {
				jframe.pack();
Re: SwingNode - ClassNotFoundException [message #1401998 is a reply to message #1401995] Wed, 16 July 2014 07:08 Go to previous messageGo to next message
I frankly don't know but what I know is that you can get rid of this
dirty threading stuff. Simply launch with
"-Djavafx.embed.singleThread=true" then FX & Swing run on the same event
thread!
Tom
On 16.07.14 13:02, Danny Tramnitzke wrote:
> ok, thanks!
> Now, my java.awt.Label is not displayed at the Swing-Part :( But it runs
> @PostConstruct
> @Override
> public void run() {
> Swing component
> add(swingLabel);
> public void run() {
> jframe.pack();
Re: SwingNode - ClassNotFoundException [message #1402174 is a reply to message #1401998] Wed, 16 July 2014 12:34 Go to previous messageGo to next message
Thomas Schindl wrote on Wed, 16 July 2014 07:08
thread!
Tom
Restricting to only one thread helps when resizing the application window. Now the Java-Fx Part does not resize slowly after the JFX container window.
But is has not effect on displaying the content of JPanel. My label is still missing.
The JPanel itself is being rendered, which I can see, when I change the background color of it.
setBackground(Color.CYAN);
PS: sorry for the duplicate posts before! I asked the webmaster of eclipse forums. There have been some technical problems this afternoon.
Re: SwingNode - ClassNotFoundException [message #1402264 is a reply to message #1402174] Wed, 16 July 2014 15:29 Go to previous messageGo to next message
Are you sure one can include AWT-Components? I just tried with JLabel &
JButton whereas AWT-Label/AWT-Button and they work but performance at
least on OS-X is unusable once the swingnode scaling, ... is useable
even on the latest 8u20 build!
Tom
>> thread!
>> Tom
> container window. But is has not effect on displaying the content of
Re: SwingNode - ClassNotFoundException [message #1402646 is a reply to message #1402264] Thu, 17 July 2014 05:31 Go to previous messageGo to next message
I see, at least JLabel works!
I want to integrade an old custom swing compontent in an efxclipse application.
It uses some AWT components itself. I will try to replace them with according Swing components.
Performance: I still have to check that
Re: SwingNode - ClassNotFoundException [message #1402803 is a reply to message #1402646] Thu, 17 July 2014 10:23 Go to previous message
All I can say SwingNode-Performance on OS-X is not OK at least on my
system but that is not a problem of efxclipse but I can reproduce the
same standalone app so the perf problem is not introduced by efxclipse.
Tom
> application.
Previous Topic:Error Loading Hooks on Luna
Next Topic:Layout of MParts that are referenced by MPlaceholders
Current Time: Sat Jul 19 11:53:15 EDT 2025
Powered by FUDForum. Page generated in 0.33568 seconds
