Home » Language IDEs » Java Development Tools (JDT) » Ant not running with JDK 1.5
Ant not running with JDK 1.5 [message #1402116] Wed, 16 July 2014 10:48
(Hope this is the most suitable forum for this..)
Using Luna (JEE build for Linux 64bit on Kubuntu 14.04) I cannot run ant-scripts with a JDK 1.5 (needed because we are calling an old Weblogic JSP compiler from within).
Any execution of an ant script (even a simple hello-world like below) does NOT run, that means immediately terminate without any feedback (also nothing in the workspace .metadata logs).
<project default="hello" name="hello_world">
  <target name="hello">
    <echo message="Hello, World"/>
    <echo>Java Version via Ant: ${ant.java.version}</echo>
    <echo>Java Version System Prop: ${java.version}</echo>
  </target>
</project>
Tried with a sun-jdk 1.5.0.22, but same when using a more recent OpenJDK behind a "J2SE-1.5 Environment".
Only when using a newer JDK 1.6 up or the "same JRE as workspace" (which is an OpenJDK 1.7) ant scripts are starting / running.
Besides: running the said JSP compiler with 1.7 takes about 8 times the time running it outside Eclipse with JDK 1.5, about 12 minutes - strange.. (if the results would be OK is not verified - we want to stick with 1.5 for the moment)
Currently running externally (the even newer ant 9.3 there has no problem with a JDK 1.5 - Luna includes 9.2)
[edit: also tried to replace the included ant 9.2 with an older 1.8.4 - no difference - ant not starting with any JDK 1.5 set as JRE]
So - any known ant problems in Luna, no one else has this (or simply no one left using JDK 1.5)?
Thanks for any hint.
[Updated on: Thu, 17 July 2014 11:02] by Moderator
Previous Topic:Eclipse Error - JVM terminated. exit code = -1
Next Topic:Append to java.library.path for Subclipse and JavaHL
Current Time: Sun Jul 20 02:39:03 EDT 2025
Powered by FUDForum. Page generated in 0.03747 seconds
