Home » Eclipse Projects » Eclipse Scout » Page closing issue
Page closing issue [message #1401979] Wed, 16 July 2014 06:32 Go to next message
I have an application which has a table node page to the left and an associated table page to the right.
The problem is that when a user hits the right hand close window button, the window closes and can never be re-opened without restarting the application.
This applies to all nodes on the left hand side, double clicking any of these nodes no longer opens the table page on the right.
I have attached an image of the app for clrification.
  • Attachment: issue.png
    (Size: 22.20KB, Downloaded 135 times)
Re: Page closing issue [message #1402048 is a reply to message #1401979] Wed, 16 July 2014 08:36 Go to previous messageGo to next message
What scout version are you using?
From the screenshot I can see that you have SWT.
What is your Eclipse Runtime Platform (3.8 or 4.x)? [defined in your Target Platform]
Re: Page closing issue [message #1402188 is a reply to message #1401979] Wed, 16 July 2014 13:00 Go to previous messageGo to next message
I could reproduce it with Eclipse Scout Luna and a 3.8 target platform.
I am not sure to know what the solution is (or at least a workaround).
I have noticed the empty AbstractScoutView.setCloseEnabledFromScout(boolean).
This is not a good sign: somehow implementation is missing.
I think you should open a Bug.
Re: Page closing issue [message #1402665 is a reply to message #1401979] Thu, 17 July 2014 06:07 Go to previous messageGo to next message
Try to add the following code block at the end of the Perspective.createInitialLayout(IPageLayout) method.
IViewLayout centerViewLayout = layout.getViewLayout(CenterView.class.getName());
if (centerViewLayout != null) {
  centerViewLayout.setCloseable(false);
  centerViewLayout.setMoveable(false);
Hope that helps...
/andreas
Re: Page closing issue [message #1403550 is a reply to message #1402665] Thu, 24 July 2014 07:11 Go to previous message
Thanks I'll give it a try .....
Previous Topic:Setting Ctrl-+ as keystroke on a table
Next Topic:ProposalField in RAP and SWT
Current Time: Sat Jul 19 21:09:10 EDT 2025
Powered by FUDForum. Page generated in 0.03596 seconds
