Home » Modeling » TMF (Xtext) » JvmType Reference in XText DSL based on XCore model [Luna]
JvmType Reference in XText DSL based on XCore model [Luna] [message #1401223] Tue, 15 July 2014 05:58 Go to next message
I'm currently building a DSL with XText that is based on a XCore model. This was previously still based on Eclipse Juno (XCore 1.0.x, XText 2.4.x) and now I'm trying to update to Eclipse Luna (XCore 1.2.x, XText 2.6.x).
With the Juno variant the usage of JvmType in both the XCore model and the XText grammar worked fine.
When updating to Luna I get errors that the expected type JvmType is not compatible with the type JvmType (detailed error see example below).
I also created a simple example with a fresh XCore project and a fresh XText DSL like the following:
XCore
package appmodel
import org.eclipse.xtext.common.types.JvmType
class Foo {
	String foobar
	refers JvmType javaClass
XText Grammar
grammar appdsl.AppDsl with org.eclipse.xtext.common.Terminals
import "appmodel"
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as jvmTypes
Foo:
	{Foo}
	'type' foobar=STRING '>' javaClass=[jvmTypes::JvmType]
Though the XText grammar yields the following error at the assignment of the javaClass feature:
Cannot find compatible feature javaClass in sealed EClass Foo from imported package appmodel: The existing reference 'javaClass' has an incompatible type 'JvmType'. The expected type is 'JvmType'.
I'm currently unsure why this worked in the Juno based version before, any ideas?
I also attached my test project, which has been checked in a Luna RCP with XCore 1.2.0 and XText 2.6.2.
Re: JvmType Reference in XText DSL based on XCore model [Luna] [message #1401245 is a reply to message #1401223] Tue, 15 July 2014 06:37 Go to previous messageGo to next message
did you have a look at http://koehnlein.blogspot.de/2013/06/using-xcore-in-xtext.html?
Re: JvmType Reference in XText DSL based on XCore model [Luna] [message #1401265 is a reply to message #1401245] Tue, 15 July 2014 07:15 Go to previous messageGo to next message
Hi Christian,
yes I actually used that article as the base for the upgrade, together with the info from the following bugzillas:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=379999
https://bugs.eclipse.org/bugs/show_bug.cgi?id=412429
I just ran the generator again an at generation time the following error is thrown:
145  [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Adding generated EPackage 'org.eclipse.xtext.xbase.XbasePackage'
266  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
269  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
280  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
280  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
1123 [main] ERROR ipse.xtext.generator.LanguageConfig  - Error loading 'platform:/resource/appmodel/model/appmodel.xcore': [XtextLinkingDiagnostic: null:7 Couldn't resolve reference to GenBase 'JvmType'.]
1993 [main] ERROR ipse.xtext.generator.LanguageConfig  - [TransformationDiagnostic: null:8 Cannot find compatible feature javaClass in sealed EClass Foo from imported package appmodel: The existing feature 'javaClass' has an incompatible type 'EJavaObject' [java.lang.Object]. The expected type is 'JvmType' [org.eclipse.xtext.common.types.JvmType]. (ErrorCode: CannotCreateTypeInSealedMetamodel)]
This seems very odd to me as the genmodel for JvmTypes is registered (see log) before it is not found anymore. What is also strange, is that here the last line indicates that EJavaObject has been found as the type of the javaClass feature whereas the IDE integration states something different.
Re: JvmType Reference in XText DSL based on XCore model [Luna] [message #1401365 is a reply to message #1401265] Tue, 15 July 2014 09:43 Go to previous messageGo to next message
can you file a bugzilla?
Re: JvmType Reference in XText DSL based on XCore model [Luna] [message #1401411 is a reply to message #1401365] Tue, 15 July 2014 11:19 Go to previous messageGo to next message
Sure, I'll do that tomorrow since it seems that it still works when exporting the *.xcore to a *.ecore.
Re: JvmType Reference in XText DSL based on XCore model [Luna] [message #1401926 is a reply to message #1401411] Wed, 16 July 2014 05:02 Go to previous messageGo to next message
Here is the bugreport:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=439682
However, it is only about the errors displayed in the editor as the mwe2 workflow can be executed if a
loadedResource = "platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel"
is specified.
Csaba
Re: JvmType Reference in XText DSL based on XCore model [Luna] [message #1401935 is a reply to message #1401411] Wed, 16 July 2014 05:15 Go to previous message
However, it is only about the errors shown in the editor, as the mwe2 workflow can be executed, if a
is added.
Csaba
Previous Topic:[Xtext] managing large numbers of rules
Next Topic:[xtext] about EMF created by xtext
Current Time: Sat Jul 19 05:48:35 EDT 2025
Powered by FUDForum. Page generated in 0.05384 seconds
