Home » Newcomers » Newcomers » Eclipse on 64-bit Windows 7(Solved)
Eclipse on 64-bit Windows 7 [message #495526] Thu, 05 November 2009 04:16 Go to next message
I recently installed Windows 7 (64-bit) onto my laptop. I am a college student with a major in computer science and I am learning Java. Eclipse IDE for Java Developers worked perfectly fine with my 64-bit Windows Vista, but now, every time I try to open Eclipse, I get this error message:
A Java Runtime Environment (JRE) or Java Development Kit (JDK) must be available in order to run Eclipse. No Java virtual machine was found after searching the following locations:
C:\Users\Corbyn\Desktop\eclipse\jre\bin\javaw.exe
javaw.exe in your current PATH
I'm not completely sure what it's asking for, so help would be greatly appreciated
EDIT: Forgot to mention that there is no such folder ( \jre ) in my eclipse directory.
[Updated on: Mon, 17 March 2014 16:58] by Moderator
Re: Eclipse on 64-bit Windows 7 [message #495617 is a reply to message #495526] Thu, 05 November 2009 09:08 Go to previous messageGo to next message
> appreciated
I can't specifically answer your question, but as noted frequently in
this forum, you should specifically use the -vm switch in your
eclipse.ini file to avoid such trouble.
http://wiki.eclipse.org/Eclipse.ini
Russ Bateman
Re: Eclipse on 64-bit Windows 7 [message #495632 is a reply to message #495526] Thu, 05 November 2009 09:41 Go to previous messageGo to next message
In article <hcu54s$hs1$1@build.eclipse.org>, cjohnson1991@gmail.com
says...
It's telling you it can't find the JRE that eclipse needs to run. Have
you installed one?
/~\ The ASCII
\ / Ribbon Campaign
X Against HTML
/ \ Email!
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: Eclipse on 64-bit Windows 7 [message #495779 is a reply to message #495632] Thu, 05 November 2009 22:38 Go to previous messageGo to next message
I have the JRE downloaded and installed. now how do i point eclipse to the javaw.exe file?
Re: Eclipse on 64-bit Windows 7 [message #495784 is a reply to message #495617] Thu, 05 November 2009 22:58 Go to previous messageGo to next message
Problem solved, thank you
Re: Eclipse on 64-bit Windows 7 [message #496069 is a reply to message #495779] Sat, 07 November 2009 15:58 Go to previous messageGo to next message
> the javaw.exe file?
Read the link that was posted earlier in this thread.
Re: Eclipse on 64-bit Windows 7 [message #511126 is a reply to message #495526] Fri, 29 January 2010 21:48 Go to previous messageGo to next message
I am having the same problem as the original poster, I tried doing the fixes posed in the link (I.E. adding those commands to the .ini file), but when i do that, it seems like clicking the eclipse.exe does nothing. Any suggestions/ideas?
[Updated on: Fri, 29 January 2010 21:48] by Moderator
Re: Eclipse on 64-bit Windows 7 [message #511249 is a reply to message #511126] Sun, 31 January 2010 15:35 Go to previous messageGo to next message
Try to see if your path variable is set... go to My Computer properties > Advanced system settings > under Advanced tab you have the Environment variables button, click it, and under System variables you should have the path variable. That variable is a list of paths that allow you to access exe's from anywhere just by typing their name and those paths are separated by semi-colon (;)... in there you should have something like ;C:\Program Files (x86)\Java\jre6\bin
If you don't have it, you either need to install JRE... and as a side note, you'll only need the 32-bit one, no need for 64-bit one at all... but if you do have it installed, just look up the path of java.exe and add it to that string... also don't end it with a ; or a \ and don't put the path in quotes.
[Updated on: Sun, 31 January 2010 15:35] by Moderator
Re: Eclipse on 64-bit Windows 7 [message #511983 is a reply to message #511249] Wed, 03 February 2010 10:17 Go to previous messageGo to next message
> the path in quotes.
I would recommend AGAINST adding Java to the system path, especially if
you want to maintain multiple versions of Java on your system. Using
eclipse.ini (instructions posted above via wiki link) is the best way to
specify what JVM you want Eclipse to run in.
Eric
Re: Eclipse on 64-bit Windows 7 [message #511991 is a reply to message #511126] Wed, 03 February 2010 10:27 Go to previous messageGo to next message
Ryan wrote on Fri, 29 January 2010 21:48
It could be a problem with how you formatted eclipse.ini - as the wiki page says, the format is very particular. Double-check what you've done and even post it here for us to review, if you want.
Eric
Re: Eclipse on 64-bit Windows 7 [message #647671 is a reply to message #495632] Fri, 07 January 2011 12:01 Go to previous messageGo to next message
I did it and now i have message that i dont have VM in folder where it actually is. What should I do?
Re: Eclipse on 64-bit Windows 7 [message #648032 is a reply to message #647671] Mon, 10 January 2011 16:51 Go to previous messageGo to next message
You did what? Be specific, and refer to already-supplied advice.
Eric
Re: Eclipse on 64-bit Windows 7 [message #648874 is a reply to message #495526] Fri, 14 January 2011 14:27 Go to previous messageGo to next message
I'm having the same problem. Edited the system environment variables AND the eclipse.ini. Now I get the error on the attached image.
Here is my eclipse.ini:
-startup
plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1. 1.R36x_v20100810
-product
org.eclipse.epp.package.reporting.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
-vm
C:\Program Files (x86)\Java\jdk1.6.0_23\jre\bin\javaw.exe
openFile
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
http://www.fun4u.com/eclipse.jpg
[Updated on: Fri, 14 January 2011 19:58] by Moderator
Re: Eclipse on 64-bit Windows 7 [message #648893 is a reply to message #648874] Fri, 14 January 2011 19:24 Go to previous messageGo to next message
Your message is devoid of all context and must refer to an earlier
thread from which it is disassociated.
I can tell you right now, however, that you're telling the Eclipse that
uses this .ini file to use a 32-bit JRE. That's a no-no if your Eclipse
is in fact a 64-bit one, which it appears to be.
> -startup
> --launcher.library
> 1.R36x_v20100810
> -product
> openFile
> 256M
> -showsplash
> 256m
> -vm
> openFile
> -vmargs
> -Xms40m
> -Xmx512m
Re: Eclipse on 64-bit Windows 7 [message #648942 is a reply to message #648874] Sat, 15 January 2011 21:09 Go to previous messageGo to next message
This is great...This will be very helpful...I'll take this as my future reference...Thanks!
Re: Eclipse on 64-bit Windows 7 [message #1272280 is a reply to message #495784] Mon, 17 March 2014 10:36 Go to previous messageGo to next message
how to solve this error
Re: Eclipse on 64-bit Windows 7 [message #1401210 is a reply to message #1272280] Tue, 15 July 2014 05:37 Go to previous message
This error happens when a JVM 32-bit (JRE/JDK) is tried to be used with an Eclipse 64-bit or otherwise.
Previous Topic:ant build and cvs
Next Topic:Optional DATE Parameter in BIRT
Current Time: Sun Jul 20 13:22:58 EDT 2025
Powered by FUDForum. Page generated in 0.32359 seconds
