ant build and cvs [message #1401204] |
Tue, 15 July 2014 05:28 |
I am using a simple ant script to try to checkout a project with a particular CVS tag into an eclipse workspace. I can see the file in the file system but just not in the eclipse workspace.
I have google searched and have seen an option of opening the eclipse workspace and then manually importing the project. I have also seen the RAD importProject task but I'm not using RAD. I have also seen an option of having to use a gradle task to make the projects visible in eclipse.
My ant build file is as below:
<project name="Automated CVS checkout" basedir="." default="checkout">
<property name="user" value="username:password@domain"/>
<property name="module" value="projectName"/>
<property name="cvsroot" value=":pserver:${user}:2401:/cvs/myrepo"/>
<property name="extract.dir" value="C:\Testing\eclipse-ant\workspacetestscript"/>
<property name="cvs.stream" value="cvs_tag_20140601"/>
<property name="log.filename" value="./cvsextract"/>
<target name="checkout">
<cvs cvsroot="${cvsroot}" cvsrsh="ssh" dest="${extract.dir}" command="checkout -d ${module} -P -r ${cvs.stream} fullPathNameInCVSRepo" output="${log.filename}m.log" quiet="true"/>
</target>
</project>
Is it at all possible to make cvs projects visible in eclipse by using an ant script or does it need manual intervention or other tools (RAD, Gradle)?
FUDForum. Page generated in 0.14044 seconds
