Home » Archived » Visual Editor (VE) » Errors in VE
Errors in VE [message #140073] Wed, 29 August 2007 23:17 Go to next message
I'm using Eclipse 3.3 with JRE 1.6 and Eric magnifgant VE port. I am
getting the following error though:
java.lang.RuntimeException: java.io.NotSerializableException:
org.eclipse.ve.internal.cdm.model.Rectangle
at
org.eclipse.emf.ecore.impl.EFactoryImpl.convertToString(EFac toryImpl.java:65
0)
at
org.eclipse.ve.internal.cdm.impl.CDMFactoryImpl.convertViewR ectangleToString
(CDMFactoryImpl.java:377)
at
org.eclipse.ve.internal.cdm.impl.CDMFactoryImpl.convertToStr ing(CDMFactoryIm
pl.java:136)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.convertToString (XMLHelperImpl.j
ava:1570)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.getDatatypeValue( XMLSaveImpl.java
:2887)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveDataTypeSingl e(XMLSaveImpl.ja
va:1609)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:119
6)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:25
90)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1105
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:986)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.jav
a:2291)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:146
4)
at
90)
at
at
at
a:2291)
at
4)
at
90)
at
at
at
a:2291)
at
4)
at
90)
at
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:
90)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:585)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:253)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:2
05)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1253
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:964)
at
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VE
ModelCacheUtility.java:158)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.primDoSave(Ja
vaSourceTranslator.java:1397)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSo
urceTranslator.java:1411)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$3.doRun(JavaS
ourceTranslator.java:956)
at
org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParser
Job.java:56)
Caused by: java.io.NotSerializableException:
at java.io.ObjectOutputStream.writeObject0(Unknown Source)
at java.io.ObjectOutputStream.writeObject(Unknown Source)
at
org.eclipse.emf.ecore.impl.EFactoryImpl.convertToString(EFac toryImpl.java:64
5)
.... 34 more
Any ideas?
Re: Errors in VE [message #140085 is a reply to message #140073] Thu, 30 August 2007 12:51 Go to previous messageGo to next message
James,
I can't really comment on what's wrong in VE. But I can point out to
the folks working on VE that in EMF 2.3 we changed EJavaObject to be
serializable, i.e., we changed EDataType.isSerializable to true for
EJavaObject and we provided support for that directly in EFactoryImpl
via a new method convertToString(Object) which uses java.io.Serializable
to serialize the results to a byte array and then encodes that byte
array has hex. So when this method is called, the instance object must
support java.io.Serializeable. I wouldn't generally expect generated
code to call this EFactoryImpl method except for array types which
otherwise couldn't be serialized without writing specialized code. So
it seems likely that convertViewRectangleToString needs to be
specialized to do something more appropriate. I wonder if this is a new
data type?
> at
> 0)
> at
> at
> pl.java:136)
> at
> ava:1570)
> at
> :2887)
> at
> va:1609)
> at
> 6)
> at
> 90)
> at
> at
> at
> a:2291)
> at
> 4)
> at
> 90)
> at
> at
> at
> a:2291)
> at
> 4)
> at
> 90)
> at
> at
> at
> a:2291)
> at
> 4)
> at
> 90)
> at
> 90)
> at
> 05)
> at
> at
> at
> at
> at
> at
> at
> Job.java:56)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> at
> 5)
> ... 34 more
> Any ideas?
Re: Errors in VE [message #140215 is a reply to message #140085] Mon, 03 September 2007 13:00 Go to previous message
Hello James,
i wonder why you get this error. I have fixed this already in the second
update, with help from Rich Kulp.
Greetings
Erik
Ed Merks schrieb:
> James,
> data type?
>> at
>> 0)
>> at
>> at
>> pl.java:136)
>> at
>> ava:1570)
>> at
>> :2887)
>> at
>> va:1609)
>> at
>> 6)
>> at
>> 90)
>> at
>> at
>> at
>> a:2291)
>> at
>> 4)
>> at
>> 90)
>> at
>> at
>> at
>> a:2291)
>> at
>> 4)
>> at
>> 90)
>> at
>> at
>> at
>> a:2291)
>> at
>> 4)
>> at
>> 90)
>> at
>> 90)
>> at
>> at
>> 05)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Job.java:56)
>> at
>> 5)
>> ... 34 more
>> Any ideas?
Re: Errors in VE [message #616414 is a reply to message #140073] Thu, 30 August 2007 12:51 Go to previous message
James,
data type?
> at
> 0)
> at
> at
> pl.java:136)
> at
> ava:1570)
> at
> :2887)
> at
> va:1609)
> at
> 6)
> at
> 90)
> at
> at
> at
> a:2291)
> at
> 4)
> at
> 90)
> at
> at
> at
> a:2291)
> at
> 4)
> at
> 90)
> at
> at
> at
> a:2291)
> at
> 4)
> at
> 90)
> at
> 90)
> at
> 05)
> at
> at
> at
> at
> at
> at
> at
> Job.java:56)
> at
> 5)
> ... 34 more
> Any ideas?
Re: Errors in VE [message #616426 is a reply to message #140085] Mon, 03 September 2007 13:00 Go to previous message
Hello James,
Greetings
Erik
Ed Merks schrieb:
> James,
> data type?
>> at
>> 0)
>> at
>> at
>> pl.java:136)
>> at
>> ava:1570)
>> at
>> :2887)
>> at
>> va:1609)
>> at
>> 6)
>> at
>> 90)
>> at
>> at
>> at
>> a:2291)
>> at
>> 4)
>> at
>> 90)
>> at
>> at
>> at
>> a:2291)
>> at
>> 4)
>> at
>> 90)
>> at
>> at
>> at
>> a:2291)
>> at
>> 4)
>> at
>> 90)
>> at
>> 90)
>> at
>> at
>> 05)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Job.java:56)
>> at
>> 5)
>> ... 34 more
>> Any ideas?
Previous Topic:VE, Eclipse 3.3, and Vista
Next Topic:Poor VE Performance
Current Time: Sat Jul 19 05:32:50 EDT 2025
Powered by FUDForum. Page generated in 0.04810 seconds
