Home » Modeling » EMF » migration: EString attribute to ERference
migration: EString attribute to ERference [message #1398837] |
Fri, 11 July 2014 13:24  |
From version n to version n+1, an EAttribute of type EString is changed
to be a EReference. The original string attribute is moved into a newly
allocated object that's then set as the reference value (no worries,
containment is handled too).
I do this in a customized XMLHandler.handleForwardReferences(), and that
seems to work for simple test cases. But is there a guarantee that it
works for arbitrary content, or is there a possibility that
deserialisation bails out earlier, say because the attribute value
cannot ever be a reference to another object because of serialization
constraints for EReferences that I'm unaware of?
Thanks for comments,
Felix
Re: migration: EString attribute to ERference [message #1400384 is a reply to message #1398837] |
Mon, 14 July 2014 01:58   |
Felix,
It depends on the string value itself. If it contains a #, it will look
like a proxy URI and be treated as such. If it contains a ":" it will
look like a QName and will be looked up as type type of object to create
for the following value. If it just looks like an ID, then it will be
looked up...
On 11/07/2014 7:24 PM, Felix Dorner wrote:
> changed to be a EReference. The original string attribute is moved
> into a newly allocated object that's then set as the reference value
> (no worries, containment is handled too).
> that seems to work for simple test cases. But is there a guarantee
> that it works for arbitrary content, or is there a possibility that
> Felix
Re: migration: EString attribute to ERference [message #1400496 is a reply to message #1400450] |
Mon, 14 July 2014 05:34   |
Felix,
Comments below.
On 14/07/2014 10:03 AM, Felix Dorner wrote:
> Hello,
>> looked up...
> Yes I've seen that there's more behind it. Another issue is
> whitespace.. The attribute contains simple text, so each token is
> treated as a separate reference which is not what I want. I checked
> the next method higher up would be setValueFromId. I'll see if I can
> handle it better from there.
Exactly.
> A different idea I had was if I could maybe use extended metadata to
> "protect" the reference from being set by mapping it to some dummy
> name, then, record unknown features to conserve the attribute value,
> and set the reference afterwards. Would that make sense to you?
Yes, though probably more direct would have been to leave the old
attribute in the model, deprecate it, make it transient, suppress its
visibility, and then transform the value in that attribute to a
reference, perhaps as a post load step or perhaps directly in the
attribute's setter, all without messing with the deserializer.
> Felix
Re: migration: EString attribute to ERference [message #1400509 is a reply to message #1400496] |
Mon, 14 July 2014 05:50  |
That sounds very nice too.
Current Time: Sun Jul 20 08:08:32 EDT 2025
Powered by FUDForum. Page generated in 0.03378 seconds
