Home » Newcomers » Newcomers » Built javascript not being published to wtpwebapps
Built javascript not being published to wtpwebapps [message #1399054] Fri, 11 July 2014 20:54 Go to next message
Hi, I'm building a web application that involves converting java code to javascript code. The javascript code is created in a separate project when the java project is built. However, when I build the java code, the updated javascript code is not sent to the wtpwebapps folder. I have to touch the javascript code every time (ie, make a token change) to get it to publish to wtpwebapps. I'm using version "Kepler service release 2", build id: 20140224-0627.
Re: Built javascript not being published to wtpwebapps [message #1399512 is a reply to message #1399054] Sat, 12 July 2014 15:24 Go to previous messageGo to next message
hmmmm.....over 200 views and nobody has a solution to the problem. This is apparently not an issue with previous versions of eclipse and my boss wants to know how to get around this when he upgrades to this version. Any help would be appreciated.
Re: Built javascript not being published to wtpwebapps [message #1399528 is a reply to message #1399512] Sat, 12 July 2014 15:57 Go to previous messageGo to next message
For one thing, you've asked an Eclipse web tools platform question in
the newcomer's forum. Not every responder here is both a Java web
developer with the sort of JavaScript experience you're asking for. Were
I you, I'd try the Eclipse WTP forum.
Re: Built javascript not being published to wtpwebapps [message #1399572 is a reply to message #1399054] Sat, 12 July 2014 17:34 Go to previous messageGo to next message
You indicate that the javascript code is created automatically. If the
process that creates the javascript code isn't using Eclipse Resource
API to create/update the files, then Eclipse won't know about the change
until the file is changed in Eclipse or you do a refresh on the file.
Check to see if the process that generates the javascript has a refresh
setting. You can also try refreshing the javascript project after the
build.
Re: Built javascript not being published to wtpwebapps [message #1400792 is a reply to message #1399572] Mon, 14 July 2014 14:24 Go to previous message
Thanks for the suggestion. I've been informed that the project doesn't use the Eclipse Resource API. However, I have tried refreshing the compiled project and it doesn't seem to make a difference.
[Updated on: Mon, 14 July 2014 14:24] by Moderator
Previous Topic:Eclipse can't find my JAVA?
Next Topic:Luna GUI missing dialog controls and borders
Current Time: Sun Jul 20 16:42:23 EDT 2025
Powered by FUDForum. Page generated in 0.08655 seconds
