Minimal Standalone Help Doesn't Launch [message #1398173] |
Thu, 10 July 2014 14:42  |
When I follow the instructions in Eclipse help, "[Optional] Installing a minimal stand-alone help system" and then attempt to launch standalone help using:
java -classpath C:\EclipseTemp1\eclipse\plugins\org.eclipse.help.base_3.5.0.v201006080911.jar org.eclipse.help.standalone.Help -command displayHelp -eclipsehome C:\EclipseTemp1\eclipse
I receive the error, "The Eclipse executable launcher was unable to locate its companion shared library". Many web posts say this is an unzip error, but I've tried jzip and 7zip and it doesn't help. Also, the full version launches standalone help just fine.
I was using Eclipse Kepler but went back to Helios, just after a fix for the min. standalone was implemented, but I get the same result. I am on Windows 7 64-bit, and have 64-bit Java and Eclipse. The Helios file is eclipse-rcp-helios-win32-x86_64.zip.
I've tried adding back some zip files that look related, but no luck.
Any ideas or help would be appreciated. If this is a stupid question that has already been answered elsewhere, please point me to this and I will be happy!
Re: Minimal Standalone Help Doesn't Launch [message #1403442 is a reply to message #1398814] |
Wed, 23 July 2014 12:48  |
I was able to get my plugin visible by doing the following:
1. Copying it into the "plugins" dir.
2. Editing the "config.ini" file so that: org.eclipse.update.reconcile=true
3. Displaying the help on the command line by using the instructions in the help, but adding "-clean" to the line.
FUDForum. Page generated in 0.09107 seconds
