Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore] IndexOutOfBoundsException when adding EClass object to EReference feature
[EMFStore] IndexOutOfBoundsException when adding EClass object to EReference feature [message #1396853] Tue, 08 July 2014 18:11 Go to next message
We have a model, stored in EMFStore, at the root of the ECPProject. In it we have a certain EObject that has a non-containment EReference with an EClass reference type. When we try to add an EClass that comes from a platform ecore, we get the following IndexOutOfBoundsException:
!ENTRY org.eclipse.emf.emfstore.common.model 2 2 2014-07-08 16:13:31.274
!MESSAGE EObject Change Observer threw an exception: org.eclipse.emf.emfstore.internal.client.model.impl.OperationManager
!STACK 0
java.lang.IndexOutOfBoundsException: Index: 4, Size: 4
    at java.util.ArrayList.rangeCheck(ArrayList.java:635)
    at java.util.ArrayList.get(ArrayList.java:411)
    at org.eclipse.emf.emfstore.internal.client.model.impl.OperationRecorder.createCreateDeleteOperation(OperationRecorder.java:421)
    at org.eclipse.emf.emfstore.internal.client.model.impl.OperationRecorder.modelElementAdded(OperationRecorder.java:217)
    at org.eclipse.emf.emfstore.internal.client.model.impl.OperationManager.modelElementAdded(OperationManager.java:259)
    at org.eclipse.emf.emfstore.internal.common.model.impl.NotifiableIdEObjectCollectionImpl$1.run(NotifiableIdEObjectCollectionImpl.java:108)
    at org.eclipse.emf.emfstore.internal.common.model.impl.NotifiableIdEObjectCollectionImpl$2.run(NotifiableIdEObjectCollectionImpl.java:142)
    at org.eclipse.emf.emfstore.common.ESSafeRunner.run(ESSafeRunner.java:38)
    at org.eclipse.emf.emfstore.internal.common.model.impl.NotifiableIdEObjectCollectionImpl.notifyIdEObjectCollectionChangeObservers(NotifiableIdEObjectCollectionImpl.java:165)
    at org.eclipse.emf.emfstore.internal.common.model.impl.NotifiableIdEObjectCollectionImpl.modelElementAdded(NotifiableIdEObjectCollectionImpl.java:111)
    at org.eclipse.emf.emfstore.internal.common.model.util.EObjectChangeNotifier.addAdapter(EObjectChangeNotifier.java:90)
    at org.eclipse.emf.ecore.util.EContentAdapter.handleContainment(EContentAdapter.java:139)
    at org.eclipse.emf.ecore.util.EContentAdapter.selfAdapt(EContentAdapter.java:74)
    at org.eclipse.emf.ecore.util.EContentAdapter.notifyChanged(EContentAdapter.java:40)
    at org.eclipse.emf.emfstore.internal.common.model.util.EObjectChangeNotifier.notifyChanged(EObjectChangeNotifier.java:187)
    at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
    at org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch(NotificationImpl.java:1027)
    at org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch(NotificationImpl.java:1032)
    at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:299)
    at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:303)
    at org.eclipse.emf.emfstore.internal.common.model.impl.ProjectImpl.addCutElement(ProjectImpl.java:244)
    at org.eclipse.emf.emfstore.internal.common.model.util.EObjectChangeNotifier.handleSingleReference(EObjectChangeNotifier.java:258)
    at org.eclipse.emf.emfstore.internal.common.model.util.EObjectChangeNotifier.notifyChanged(EObjectChangeNotifier.java:196)
    at org.eclipse.emf.ecore.util.DelegatingEcoreEList.dispatchNotification(DelegatingEcoreEList.java:355)
    at org.eclipse.emf.common.notify.impl.DelegatingNotifyingListImpl.addUnique(DelegatingNotifyingListImpl.java:296)
Would anybody have a clear idea as to why this is happening? I could give more information tomorrow morning (EST here); I'm just not sure what kind of information would be helpful here.
Thanks very much for your help.
Olivier
EDIT: just noticed I missed a few important lines from the stack trace. Notice the addCutElement() call.
[Updated on: Tue, 08 July 2014 18:24] by Moderator
Re: [EMFStore] IndexOutOfBoundsException when adding EClass object to EReference feature [message #1396867 is a reply to message #1396853] Tue, 08 July 2014 18:43 Go to previous messageGo to next message
Ok, after a quick look at some of the code, I realized the org.eclipse.emf.emfstore.ecore plugin isn't in our target platform. With it, the EClass object should not be added to the "cut elements" due to being a singleton, thus this whole issue should then be prevented.
Any reason why this plugin wouldn't be installed when installing the EMFStore SDK from the p2 repo? I'm thinking it's rather important, no?
Tomorrow morning I'll be able to test this and report on my findings.
Olivier
Re: [EMFStore] IndexOutOfBoundsException when adding EClass object to EReference feature [message #1397959 is a reply to message #1396867] Thu, 10 July 2014 07:59 Go to previous messageGo to next message
thanks for pointing this out. I agree, that it should probably be part
of the SDK, could you open a BR for this, plz?
Best Regards
Jonas
Am 09.07.2014 00:43, schrieb Olivier Labrosse:
> Regards,
> Olivier
Re: [EMFStore] IndexOutOfBoundsException when adding EClass object to EReference feature [message #1398030 is a reply to message #1397959] Thu, 10 July 2014 10:01 Go to previous message
Done. BR: https://bugs.eclipse.org/bugs/show_bug.cgi?id=439349
And I apologize for not getting back with my test results yesterday. It so happens this was the solution to our problem, adding the org.eclipse.emf.emfstore.ecore plugin to our target platform.
Olivier
Jonas Helming wrote on Thu, 10 July 2014 07:59
Best Regards
Jonas
> Regards,
> Olivier
Previous Topic:Security scan issues
Next Topic:[ECP] View validation with OCL constraints
Current Time: Sat Jul 19 12:48:10 EDT 2025
Powered by FUDForum. Page generated in 0.07080 seconds
