Home » Eclipse Projects » Eclipse 4 » Updating command contributions on handler switch
Updating command contributions on handler switch [message #1395817] Mon, 07 July 2014 08:45 Go to next message
Hy there,
as described on stackoverflow, i am trying to find a way to update all Contributions (HandledMenuItem, HandledToolItem, ...) allocated to a Command on the switch to a certain handler.
That is (plz refer to the image on stackoverflow), I have globally defined the add command, overriding it with specific behaviour on selection of the resp. part. On doing this I want to update the tooltips of all contributions.
I do not see a clear way to do this, however, but some approaches I can't seem to follow:
  • Have a list of all contributions (List<MContribution>) injected to the @CanExecute (Not supported)
  • Use the EModelService to find all contributions to a command (Not implemented)
  • Something else?
am I missing something? Is there a solution for this? If not I am willing to go for an implementation!
Re: Updating command contributions on handler switch [message #1396724 is a reply to message #1395817] Tue, 08 July 2014 13:35 Go to previous messageGo to next message
We don't have anything like this, and I don't see a bug report for tracking it. You could look at how the compat code supports IElementUpdater/ICommandService#updateElements().
Brian.
Re: Updating command contributions on handler switch [message #1396814 is a reply to message #1396724] Tue, 08 July 2014 16:43 Go to previous messageGo to next message
I did some more experiments, with different approaches. My current findings are:
On switching the parts the EclipseContext.set("handler::handler_id") is called which activates the new handler. It is possible to listen to this event using
@Inject
public void bla(@Optional @Active @Named("handler::command.add") Object value, MApplication application) {}
for example. So on any change for the given command you receive the now activated handler and may act accordingly. This solution located in an Addon, however, does not satisfy me, so I tried to implement the aforementioned into the resp. handlers. Where I have now the interesting behaviour, that on switch of the perspective (through partService.switchPerspective(perspective)) the handler is not exchanged, although the old registered handler in the new Perspective is clearly out of scope. The handler is only swapped if I select one of the parts within the Perspective (not necessarily the one part defining the new handler).
Could this be a bug? I would expect the handler to be exchanged on selecting a different Perspective?!
Re: Updating command contributions on handler switch [message #1397278 is a reply to message #1396814] Wed, 09 July 2014 09:40 Go to previous messageGo to next message
Was the active part in both perspectives?
You'll only be reinjected if the handler changed.
Brian.
Re: Updating command contributions on handler switch [message #1397829 is a reply to message #1397278] Thu, 10 July 2014 04:01 Go to previous message
Hy Brian, the problem is not with the perspectives, thats a bug with my software Smile However, I found a solution, with some deficiences outlined in a blog post http://www.descher.at/descher-vu/2014/07/e4-updating-ui-contributions-on-context-switch/
Previous Topic:Addons execution order changed in Eclipse 4.4
Next Topic:LocationManager in Eclipse 4
Current Time: Sun Jul 20 02:46:21 EDT 2025
Powered by FUDForum. Page generated in 0.05891 seconds
