Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Webkitgtk and BIRT(How to use explicitly webkitgtk)
Webkitgtk and BIRT [message #1396498] Tue, 08 July 2014 07:37 Go to next message
I use Eclipse Juno on fedora 18
Even after installing webkitgtk, webkitgtk-devel, webkitgtk3, webkitgtk3-devel, starting eclipse with command-line parameter -Dorg.eclipse.swt.browser.DefaultType=webkit, each time I want to preview a report that is created with BIRT, I get the following error:
Unhandled event loop exception
No more handles [Could not detect registered XULRunner to use]
I have added the following lines to eclips.ini:
-Dorg.eclipse.swt.browser.UseWebKitGTK=true
# -Dorg.eclipse.swt.browser.DefaultType=mozilla
# -Dorg.eclipse.swt.browser.XULRunnerPath=/usr/bin/xulrunner
When commenting the first 2 of these lines and uncommenting the last ones, I get this error:
Unhandled event loop exception XPCOM error
I have read the SWT-faq and have seen that Browser instances should be created with SWT.WEBKIT but since I can't find where I should add this, I assume that this is an instruction for RCP-applications with a browser.
My question is how to use explicitly webkitgtk in Eclipse juno?
Ben
Re: Webkitgtk and BIRT [message #1770822 is a reply to message #1396498] Thu, 17 August 2017 08:16 Go to previous message
Did you find a solution to this?
Previous Topic:JAWS doesn't read autocompletion
Next Topic:How to use push-button in SWT?
Current Time: Sun Jul 20 10:15:44 EDT 2025
Powered by FUDForum. Page generated in 0.03325 seconds
