Re: HTTP 404 [message #1395176 is a reply to message #1395076] |
Sun, 06 July 2014 09:59   |
first of all, my apologies to this forum by the white comment before, it was the browser fault .
[b][Bahtiyor Ruzimatov][/b] I appreciate your response, and your advise too.
//i changed the port in scout aplication just like you said.
When I tested in scout, all it is fine, the rap package, and the swing UI.
Then I exported my project and I let the default values.
Start tomcat, and It made the deploy, but unfortunately, i've gotten the same error.
would you mind show me xml file that is working.
see my image 4-5
Update info:
I changed tomcat 8 by tomcat 7, againg same error
Attachment: 4.PNG
(Size: 10.91KB, Downloaded 419 times)
Attachment: 5.PNG
(Size: 9.31KB, Downloaded 410 times)
[Updated on: Sun, 06 July 2014 11:47] by Moderator
Re: HTTP 404 [message #1395243 is a reply to message #1395176] |
Sun, 06 July 2014 12:28   |
1) I use: Linux 12.04 x86, Java:(build: 1.8.0_05-B13), Apache Tomchat: 8.0.9;
2) My web.xml (from testapp folder, in my case) file is same as you, I attach a file to confirm.
3) Path for my deployed application on Tomcat Server: $Catalina_home/webapps/testapp(testapp_server)
4) My browser: Firefox (version 30.0)
5) My Scout and Tomcat located same on my pc
I suggest you do the following:
1) replace localhost to 127.0.0.1
2) reinstall Tomcat to version 7
3) do again deployment for war file same as [url=http://wiki.eclipse.org/Scout/Tutorial/4.0/Deploy_to_Tomcat]. I assure you, if it turned out a lot of people, then it is true.
4) Consult the documentation for errors in Equinox, Jetty and Apache Tomcat
Usually, the error traps us in quite unexpected places.
With respect, and in the hope that you will find a solution!
Attachment: web.xml
(Size: 1.43KB, Downloaded 475 times)
FUDForum. Page generated in 0.05660 seconds
