Kill the AUT at the end of the test [message #1385689] |
Tue, 10 June 2014 09:59  |
Hi Peoples,
At the end of the test I have a shutdown action. I use a single click to exit the AUT. Then a question comes up 'Are you sure you want to exit?(Yes/No)'. Here I use a SPACE action to handle the Yes button. But if the Yes button does'nt have the focus this does'nt work.
When I use a single click action to handle the Yes button, the AUT is shut down, but Jubula thinks the test is still busy.
Since there is a restart action you should say that it should also be possible to simply kill the AUT to end the test.
Is there a straight way to end the test? That's actually the question...
If Jubula does not end the test, no execution log is generated and I have to plough through the plain text log file...
Thanks a lot for your answer!
Kind regards,
Jurjen
Re: Kill the AUT at the end of the test [message #1397575 is a reply to message #1397069] |
Wed, 09 July 2014 19:05  |
I have tested extensively this issue, with my application, happens the following.
If you close it using a "external key combination", in linux 1 out of 10 fails (and gives you the timeout error. However in windows, it fails in a proportion of 8 out of 10.
It looks like it really depends on how the OS is timesharing the applications...
FUDForum. Page generated in 0.04430 seconds
