Home » Modeling » EMF » Generating code for packages that only contain other packages
Generating code for packages that only contain other packages [message #1391795] Tue, 01 July 2014 08:21 Go to next message
I am working on a ecore model that has a package structure similiar to this:
rootp
- packA
- packB
The package rootp contains no classes, only the two packages packA and packB. When generating code from this model, no EPackage is created for rootp, only for the packages packA and packB.
This can be fixed by adding a class to the package rootp, but shouldn't there be a generated EPackage for rootp anyway? Is there an option to allow generating code for the package rootp?
I have attached an EMF project for demonstration of the problem.
Matthias
Re: Generating code for packages that only contain other packages [message #1391842 is a reply to message #1391795] Tue, 01 July 2014 09:44 Go to previous messageGo to next message
Matthias,
Nested packages are evil, and no, we generate nothing for an empty package:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=142856
Adding a "dummy" EDataType will force it to generate.
Is there is a compelling reason to have generated code that's not
capable of doing anything useful? It's hard to imagine...
On 01/07/2014 2:21 PM, Matthias Jurisch wrote:
> Hello,
> rootp
> - packA
> - packB
> Matthias
Re: Generating code for packages that only contain other packages [message #1391897 is a reply to message #1391842] Tue, 01 July 2014 11:15 Go to previous messageGo to next message
Hello Ed,
thanks for your reply. I need the generated code only for registering the rootp package for model transformation with qvt operational. The problem I have here is that the package structure is different when using dynamic and static ecore, since when using static ecore the "empty" packages do not exist. So when I try to transform models created with static ecore the transformation does not compile.
Greetings, Matthias
Re: Generating code for packages that only contain other packages [message #1391968 is a reply to message #1391897] Tue, 01 July 2014 13:27 Go to previous message
Matthias,
You're best to avoid subpackages entirely and if you can't avoid that, a
dummy EDataType will do the trick.
On 01/07/2014 5:15 PM, Matthias Jurisch wrote:
> Hello Ed,
> Greetings, Matthias
Previous Topic:ECP with generics
Next Topic:[code-gen] How to make EMF to add extra comments to the generated code
Current Time: Sat Jul 19 11:39:48 EDT 2025
Powered by FUDForum. Page generated in 0.04563 seconds
