How to make your own tab indentation size [message #1388694] |
Thu, 26 June 2014 16:38  |
All you have to do is stumble onto a page where you can Edit an existing profile.
Or in Eclipse "help", search for java editor TYPING PREFERENCES and follow the link atop the page, which opens a window titled "Typing". Click Java > Editor > Typing and look for a link under the topic "Indentation" to the "Formatter" preference page.
There, click Java > Code style > Formatter and EDIT THE ACTIVE PROFILE, MAKING WHATEVER CHANGES YOU NEED, THEN SAVE IT UNDER A NEW NAME.
As it turned out, my tabs STILL weren't right until I exited the IDE and restarted.
It really shouldn't be this hard.
Attachment: 0a.PNG
(Size: 80.13KB, Downloaded 1391 times)
Attachment: 0b.PNG
(Size: 79.35KB, Downloaded 1373 times)
Attachment: 0c.PNG
(Size: 79.38KB, Downloaded 1305 times)
Re: How to make your own tab indentation size [message #1388732 is a reply to message #1388694] |
Thu, 26 June 2014 17:56  |
Are you sure you didn't just need to close and reopen the editor within Eclipse? Regardless, it's this hard because historically it's been something that appeared to be adjustable from multiple places in the UI, and causing endless (and repeated) confusion over the years. Now there's exactly one place to control how it's supposed to behave--at least for Java sources.
FUDForum. Page generated in 0.08316 seconds
